LS1 + T56 + C4 = Good times!
Old 07-30-2010, 10:14 PM
  #61
subtlez28's Avatar
I did some work on the gas tank today. I drained it as much as I could and washed it out w water days ago. It still smells like gas but is dry. I was worried about going after the rust (explosion). Today I bit the bullet and hit it with a plastic media wheel on a drill. It cleaned up well, and no sparks...
I threw a quick coat of paint on:
Down side is the cheap bolt extractor kit I bought at AZ did not help w the two broken bolts. However I did bust several drill bits... Those tank bolts are hard!
I switched over the wiring on the late C4 sending unit. I just pulled the factory wires from the old 3 plug connector, the new 4 conector, and put the new unit wires in the old (3) connector. The new sender didn't even use the 3rd place, so I think I'm good.
I also put in my Racetronics pump and sending wiring (just 2 splices - it was for the 84 sending unit).
Old 08-01-2010, 10:44 AM
  #62
subtlez28's Avatar
I got my new (to me) harness in yesterday! I originally had an S&P harness for the LS1 and 4L60E that came in the car. I was going to modify it for the T56. But then I found a great deal on a used S&P harness for an LS1/T56 combo, so I jumped on it.
For anyone doing a similar swap with an auto, my other harness is currently in classifieds.
$650 shipped.
Old 01-25-2011, 05:28 PM
  #63
paq
paq's Avatar
any progress yet? keep up the nice works!
Old 01-25-2011, 06:03 PM
  #64
abot316's Avatar
I like it. Everytime I go out west I debate on bringing a cheap c4 home to build with the extra t56 on the shop floor. I take it you run down at Blackhawk Farms? I haven't been there since 01. I hope to get there once atleast with my 98 this year.
Old 01-26-2011, 05:48 AM
  #65
Jeff Smith's Avatar
Good job project....
Old 03-09-2011, 08:58 AM
  #66
LQC4's Avatar
Any updates?? I am catching up to you
Old 04-15-2011, 09:12 AM
  #67
LSCha0s's Avatar
I'm doing a similar swap.
https://ls1tech.com/forums/conversio...e-my-swap.html
Old 04-15-2011, 05:34 PM
  #68
subtlez28's Avatar
Thanks. I do run at BHF. Hope to see you there this summer. I run the Midwestern Council events (High speed autocross).
Originally Posted by LSCha0s
Thanks for the interest guys.
I was moving along nicely in the fall. Then I broke my collar bone. I healed up fine but I life has been in the way since. As has the Jeep Wrangler project I'm working on. I wanted a winter toy. It might get an LS1 next.
I have the engine, T56 and D44 in place. I need to build plates for the motor mounts. Then on to clutch, wiring, rebuilding the front suspension, and interior. I hope my motivation comes back as the weather gets nicer.
Old 04-16-2011, 12:51 PM
  #69
LSCha0s's Avatar
I'm glad to hear you didn't loose interest.
Old 11-29-2011, 10:54 PM
  #70
subtlez28's Avatar
This comment burns considering what I am about to type. I think it is time to poop or get off the pot on this project... We'll see what influence I get on which to take.
I'm sure I'll regret this later, but the truth is I have not made this car a priority in too long...
Would anyone who has followed this build be interested in taking over?
I'm fairly close to completion. Things that come to mind it still needs:
1- Engine mounts or plate
2- Wiring, keep in mind I have a nice plug and play engine/trans harness and ECU
3- Clutch hydraulics (have the parts)
4- Seats (the only part I really do not have at the moment)
I have new:
-Melrose Swap headers
-Dewitts LS1 Swap Radiator
-Water pump, balancer etc
-Laser cut Aluminum dash w Auto-meter Guages
Completed:
-D44 inspected and installed new rear hub/bearings and ARP studs
-Full Banski rear suspension
-Racetronics fuel pump , new classic tube fuel line
-Liberty Face-plated T56 six speed with C-beam bracket
-98 LS1 with LS6 intake and stand alone harness/ECU
-C5 front brakes
-17x11 front and 17x13 rear wheels/tires
$10k would take it home with the LS1, T56 and all mentioned parts. I have much more in it!
I would consider trades up or down (plus or minus cash). Manual trans C5, G8, GTO, CTS-V or LS1 F-bodies come to mind.
I've been pretty candid with this thread. No surprises.
I don't "need" to sell it, but I have been facing the reality I don't have time for this project at the moment...
Old 11-30-2011, 09:15 AM
  #71
85MikeTPI's Avatar
Sorry to hear this.. In working on my own LS3/T56/C4 swap, I find it hard to fall into the lure of upgrading, instead of converting, which I know will kill the project.. I think the project is much more successful if you can get it converted/running first, then go back and upgrade. Having a non-running project is a real motivation killer.
I'm all about taking projects to completion, so if I can motivate you at all, I'll try.. I'd recommend concentrating efforts on getting it running/moving again, then deal with the other stuff later..
:2cents:
Old 11-30-2011, 10:57 AM
  #72
subtlez28's Avatar
:2cents:
Good advise! If I get guilted into finishing it, rather than selling it that will work to!!
Old 11-30-2011, 11:38 AM
  #73
black87c4's Avatar
boy i feel that pain, literally. mine went out on a flat bed couple weeks ago. Was very sad to see it go but i just don't have the time required nor the back anymore
Old 11-30-2011, 11:58 AM
  #74
LSCha0s's Avatar
If its just interest you need I can email you some.
JK
But seriously.. don't give up you are close. I agree with waht was said finish the conversion then do the upgrades. It will make the job a lot easier and when your done you can slowly do the upgrades. GL I wish i were closer I would help you work on it.
Here is some motivation for you. a buddy from Digitalcorvettes.com
http://api.viglink.com/api/click?for...13226758602543
Old 12-08-2011, 11:20 AM
  #75
seadoo's Avatar
any updates?
Old 12-08-2011, 03:18 PM
  #76
subtlez28's Avatar
Originally Posted by seadoo
any updates?
Well, I listed it in the for sale section...
On the plus side I have been thinking about working on it again. I have some vacation days over X-mas. Maybe I'll get back to work.
I think I'll put the front suspension together and get it back on the ground. Maybe then it will be a car again in my mind and get me more motivated.
If I do, I'll grab some pics and get this thread updated.
Old 02-21-2012, 01:05 AM
  #77
f body lover's Avatar
Any updates? Im about to drop LS2/T56 in my bros '95 C4 its originaly manual I neef help in engine mounts and transmission mounts
Old 02-21-2012, 10:56 AM
  #78
85MikeTPI's Avatar
There's a collection of C4 conversions and tips over on CF that might help..
http://forums.corvetteforum.com/c4-g...lsx-swaps.html
There are a few here on tech also, but most people are dual-citizens.. ;-)
Old 02-21-2012, 12:43 PM
  #79
LSCha0s's Avatar
yup I started that thread. I have many faces.
Take some time to look at our builds and decide which way you are going. GJ
Old 02-21-2012, 06:19 PM
  #80
subtlez28's Avatar
No progress on my end beyond collecting some parts. I just haven't been putting in much garage time lately.
Quick Reply: LS1 + T56 + C4 = Good times!
