My Swap: 1988 RX7 - LS1/T56 w/ single turbo
Old 08-21-2011, 10:33 PM
  #41
WeeWolf's Avatar
Originally Posted by Marcello7x
Looks good, i've been waiting to see update pics.
I've been looking for someone that converted the dana get rid of the half shafts i read through this thread when you posted the pic of the rear, but didn't remeber where i saw the pic. Was it some sort of kit? does it convert directly to the rx7 hubs? Any info would be cool.
I was wondering the same thing if there was a way to just get half shafts that would replace both the stub and rx7 half shaft. If that was possible might just keep my rx7 and look for a dana 44.
Old 11-12-2011, 08:34 PM
  #42
digitalsolo's Avatar
New toy:
Old 11-17-2011, 10:07 AM
  #43
cprmn14's Avatar
Great build! I love that Ferrari coating in the intake.
How much boost are you running?
Old 06-27-2012, 10:12 PM
  #44
Turned the boost up and smoked 2nd/3rd in the 2004r. Decided to step it up a bit, so it's getting an 8.8 and a powerglide.
Here's progress on the solid axle conversion:
Old 06-30-2012, 09:50 PM
  #45
Sandmann120's Avatar
Fox rear suspension geometry?
Old 07-01-2012, 09:14 AM
  #46
speedfreak90's Avatar
keep more of these solid axle pics coming!!! great work!
Old 07-01-2012, 10:39 AM
  #47
JAX04's Avatar
Great work! That looks fantastic man!
Old 07-01-2012, 08:54 PM
  #48
Thanks guys.
Yes, it's based on Fox geometry, though the chassis side positioning is slightly different (since the Fox cars get goofy when you lower them, geometry wise), but the links used are fox parts (2003 Mach 1 specifically), but they are just mock up, everything will be rod ends/adjustable when it's complete.
Today I put the gas tank in, had to adjust it's position a bit, but it's in. Next up is finishing some bracing and building a floor, I'll post pics as I go.
Then I just need to get some $$$ and I can buy the Powerglide and get this thing back on the road.
Old 07-04-2012, 03:12 AM
  #49
gnx7's Avatar
great progress....
From BS3 to a solid rear setup! This car is gonna rip!
Old 07-05-2012, 10:30 PM
  #50
Thanks Mark, I sure hope so.
Finishing up a car for a customer right now, as soon as it's done (hopefully pretty much finished this weekend), I'll get the rear end finished up on mine.
Old 08-10-2012, 07:56 PM
  #51
New trans: Rossler Terminator 1.76, paired with a PTC converter. Yeehaw.
Attached Thumbnails My Swap:  1988 RX7 - LS1/T56 w/ single turbo-2012-08-10-19.10.20.jpg
Old 05-15-2014, 08:38 AM
  #52
So, time for some updates...
Repainted the car to stain charcoal metallic and got some new wheels:
Changed from BS3 to ProEFI:
That necessitated a brand new harness from scratch:
And added flex fuel capability:
Moved to ID1300 injectors:
Redid the exhaust:
And mostly reassembled:
I'm also utilizing ABS sensors for wheel speed to allow full closed loop traction control in the car, as well as 4 port boost controller to allow me to run a 4 lbs gate spring but still run 20+ psi of boost.
Attached Thumbnails My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_jambs.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_jambs2.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_enginebay.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_installed.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_harness.jpg
My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_flexfuel.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_weld.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_injector.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_bay.jpg   My Swap:  1988 RX7 - LS1/T56 w/ single turbo-proefi_wheels_paint.jpg
Old 05-15-2014, 10:44 AM
  #53
merika's Avatar
Man i gotta learn how to weld!!
Amazing car and fab skills!!
Old 05-16-2014, 09:56 PM
  #54
Thanks. The fab work is mine, but the TIG work is done by a friend who is damn good with the torch. I'm so-so on a MIG, but I don't have a TIG, unfortunately.
Old 05-16-2014, 10:27 PM
  #55
Boostedhatch's Avatar
nice work cant wait to see it finished.
Old 08-08-2014, 08:23 PM
  #56
bwy23's Avatar
Man this makes me wanna go build somethin!!!
Old 08-10-2015, 10:48 PM
  #57
prostreet1967's Avatar
What u do with the tube on passengers side valve cover?
Where u get flex fuel sensor with an fittings? Is there a os that has flex fuel and 3 bar capability?
Old 03-24-2016, 08:37 PM
  #58
tta656's Avatar
nice work...updates???
Quick Reply: My Swap: 1988 RX7 - LS1/T56 w/ single turbo
