Has anyone here use ATS bellhousing adapter to a BBC ?
I have a 99 ls1 t56 and didn't want to go through a expense of new bell. The question is if the spacer is out 3/8 of a inch would you have to use the TO spacer if you use a traditional two piece rear main engine and factory flywheel? I have everything from the ls1 car clutch wise and have mocked up ls1 ceramic clutch and pressure plate. I also have a factory t5 roller pilot bearing that fits the input shaft. The car is 68 camaro 73 454 front gmpp front ser converstion and removed muncie any input is helpful.
