L33 Swap Help in 96 ZR2
Old 11-25-2009, 12:41 PM
OldSchoolSS's Avatar
Default L33 Swap Help in 96 ZR2
Hey guys,
After wanting an LS based engine since 98 I finally picked one up yesterday. I picked up an 06 L33 with 36,000 miles. It came with most of the brackets, and most of the sensors. It was missing the alt., PS. Pump, AC Comp., & Starter. Also it's missing the bracket that bolts the alt and PS pump to the block. If anybody knows the best & cheapest place to get these items I'd appreciate the info.
My real question lies in the wiring. I did a lot of searching but I can't seem to find what I'm looking for. The engine came with the 06 computer but no harness. I guess they cut those up pretty bad while removing the engine... What harness should I be looking for? Will any truck 03-07 work? I want to use the truck intake and accessories on my swap. Along with the DBW throttle body. Should I be looking for the truck harness or will an LS2 car harness offer a cleaner install? I think I read that the injector plugs are different between the two.
Thanks,
OldSchoolSS
Old 11-25-2009, 12:44 PM
NemeSS's Avatar
various aftermarket sources will supply you with a plug and play harness. based on your specs. all the bolts u can get from sdpc or harware store. they are all metric.
Old 11-25-2009, 01:25 PM
garys 68's Avatar
I've got a spare alternator/PS pump bracket with the PS pump off a 6.0. Where are you located?
Old 11-25-2009, 03:52 PM
I'm located in WI.
Old 11-26-2009, 06:42 AM
garys 68's Avatar
Well I guess you picking it up in person is out of the question.
I'm guessing shipping would be $30-40, so you might be able to get it from a local junkyard cheaper. If you still want it, let me know what it's worth to you.
Old 12-16-2009, 04:45 PM
Does anybody know if a 2004 6.0 harness will work with the L33? I have the connectors of the 2006 Computer that I could re-pin.
Old 12-16-2009, 05:15 PM
xpndbl3's Avatar
i have a spare bracket for the alt/power steering as well from a truck if that would help?
Old 12-16-2009, 06:48 PM
v8envy's Avatar
6.0 harness will work, however the transmission will need to be re pinned for a 4l60 and you will need a cable throttle body with an 04 I think.
Quick Reply: L33 Swap Help in 96 ZR2
