Can someone point me in the direction of were to get universal plug wires
Old 11-25-2009, 03:19 PM
73 nova guy's Avatar
Default Can someone point me in the direction of were to get universal plug wires
my setup is unique and i need some angle boots and some straights i am wondering if some on has a link for a kit that has a build your own plug wire set like the old SBC ones but with the coil pack ends?
Old 11-25-2009, 03:36 PM
LS1MCSS's Avatar
Go to Summit and order these ends, http://www.summitracing.com/parts/MSD-3304/ and whatever wires you want to put them on.
Old 11-25-2009, 04:34 PM
Pop N Wood's Avatar
I have this set
http://www.summitracing.com/parts/MSD-32829/
They are a little longer than the stockers and very good quality. The good part is the plug boot can be bent anywhere from straight to a 90° bend. Once youi bend them they hold their bend, so you won't have anytrouble customizing each plug.
Old 11-25-2009, 05:16 PM
baker67nova's Avatar
Default plug wires
i got my set from baker engineering 616-837-8975.they are scott wires you tell them what length and what ends you want.all the wires are numbered at the boot very high quality and there already made for you no hassle.took three days to get mine and $125.
Old 11-25-2009, 07:09 PM
under pressure's Avatar
I use the MSD set for the LT1. The connectors for the Optispark distributor fit the LS1 coils. From there you can use whatever plug connector you need on the other end, although some come with the kit. These are long enough to mount remote coils. I suggest you buy a set of the MSD crimpers if you don't already have them and some dilectric grease. Have fun.
Old 11-25-2009, 07:40 PM
eviltwin_1987's Avatar
https://ls1tech.com/forums/member.php?u=34219
he makes wires custom order. great prices too!!! You can get 1 to 1000 wires from him.
Old 11-25-2009, 08:12 PM
Smo's04Gto's Avatar
used same as above,was very happy with them
Old 12-07-2009, 06:58 PM
yessir's Avatar
not to hijack, but does any one know what 90 degree ends to use on the plug side?
Old 12-08-2009, 12:20 AM
71 chevy's Avatar
hi, do you have a part number, and how long is the longest one?
thanks
Quick Reply: Can someone point me in the direction of were to get universal plug wires
