Bolt in LS1 swap kits for 4wd Silverado, K5 and GM trucks 1973-1987
Old 12-17-2009, 09:41 AM
RetroLSX's Avatar
Default Bolt in LS1 swap kits for 4wd Silverado, K5 and GM trucks 1973-1987
Here is the 73-87 GM 4wd swap kit from www.RetroLSX.com This is a bolt in kit for the 4WD trucks that will let you use the OEM mounting points if you want to use the newer style transmissions with the old T-Cases. I will also sell just the mounts and the headers have already been built for the kit. I’ll have some off the car shots and more in the car late today. The kits will need to go out to be mass produced but its 100% bolt in.
An adapter bracket was used to bolt on the older style t case for this swap.
The OEM driveshafts did not even have to be modified!
I will have a lot more info to come on this swap so keep checking out this thread for more info.
Old 12-17-2009, 10:33 AM
RetroLSX's Avatar
Here are some more mock up photos that also show that the truck was level and that the motor sits in this 4WD in level.
Old 12-17-2009, 02:37 PM
Jim85IROC's Avatar
It sure would be nice to swap out the boat anchor 454 in my truck... you said it'll work with exisiting driveshafts... is that with any current trans/t-case combo, or is it specific to a certain combo (say 700R4 with NP208, etc)? My truck has a 454 with th400 & NP205 and I'm curious as to just how "bolt in" it would be. I'm guessing that a 6L80E is quite a bit longer than my TH400.
Old 12-17-2009, 04:22 PM
RetroLSX's Avatar
The kit will bolt in with any trans the only difference if not running the 4L60 then the OEM crossmember that it still used would just have to be slide back father for the larger trans. We still will be making more variations to this kit this is just the first version of the kit.
The truck was a 203 th-350
The swap
was a 4L60 / NP208
The adapters for the T-Case work with most GM t -cases. The 208 was used for ease of use when adapting and would be the easiest to swap t –case on a 4L60.
Old 12-17-2009, 04:41 PM
LS1GMCTruck's Avatar
Default LS Motor Mounts
My buddy got his mounts from Jeg's or Summit(forget which) for his LS 1987 truck installation. Looked simular to those.
Old 12-19-2009, 11:43 PM
Blackdog76's Avatar
what oil pan are you using to clear the crossmember?
Old 12-20-2009, 02:50 PM
Thumbs up Best Oil Pan...
On a 1988 thru 1998 OBS(old body style) Chevy truck, the F-Body oil pan fits like a glove. Its what everyone is using.
Old 12-20-2009, 03:13 PM
Thealien's Avatar
Any plans for a 68-72 version. I know a few people looking. The engine crossmember is an issue on non lifted trucks.
I am doing this swap now.
Old 12-20-2009, 05:04 PM
Jimbo1367's Avatar
LSX retro,
how about doing a 2nd gen F-body motor/4L65 mount swap and say 1 7/8 headers. I just hope you decide to do it before late spring when I will be forced to buy BRP's swap kit.
Old 12-21-2009, 07:53 AM
RetroLSX's Avatar
This kit works with the OEM truck oil pan so save some cash and just get a truck pullout!
It was mocked up the the LH8 but ether pan will work great.
We will also be using the truck pan on the 88-98. I have a 2wd next door to the shop we will make a kit on once we take out a few muscle cars.
Ill look into getting the 68-72 in the shop. I know the mounts will work if you use the frame plates from the 73+ style trucks.
I have my own 1976 Camaro that will be used for mock up and i already have the headers in works in stainless! So save your money and you can have a lot less $ into the kit with stainless headers over mild steal!
Old 12-21-2009, 08:08 AM
jfg455's Avatar
88-98 2wd trucks can use a truck pan with 1" set back mount plates. Stock manifolds on the 5.3-6.0 truck motors slide ride right in the chassis like they were meant to be there. Same on the 4x4 trucks. We have done one of each and they are about the easiest swap out there.
Old 01-08-2011, 07:55 PM
dieseltech71's Avatar
So just to be clear, I have a motor out of a 2005 silverado. I do not need to change the pan? I am putting it in a 1987 K5 blazer 4WD.
Old 04-30-2018, 11:20 PM
Blazer 86's Avatar
Default 87 k10
]88-98 2wd trucks can use a truck pan with 1" set back mount plates. Stock manifolds on the 5.3-6.0 truck motors slide ride right in the chassis like they were meant to be there. Same on the 4x4 trucks. We have done one of each and they are about ......
So I so I have an 86 Chevy Blazer K10 4 wheel drive thinking about putting an lq4 engine in truck engine is it going to hit my crossmember what motor mounts would I need I'm thinking about getting some solid motor mounts the adapter plate and just welding them where I want them
Old 05-02-2018, 11:11 AM
Jimbo1367's Avatar
Nice *** truck
Quick Reply: Bolt in LS1 swap kits for 4wd Silverado, K5 and GM trucks 1973-1987
