Single Turbo LS1 Notch Build *videos*
Old 06-24-2012, 05:55 PM
  #441
bad6as's Avatar
should have the car back on the 7th i cant wait
Old 06-24-2012, 07:33 PM
  #442
philsblwnz28's Avatar
very sickkkkkk car. I am looking for a notch roller and am planning on a 5.3 turbo swap. What wiring harness did you use/ECM
Old 06-27-2012, 05:09 PM
  #443
bad6as's Avatar
pre made ebay harness, and a fbody pcm
Old 06-28-2012, 07:15 AM
  #444
SKULL's Avatar
God your still building this car. JESUS CHRISTS
Old 07-08-2012, 09:40 PM
  #445
bad6as's Avatar
Well I was let down AGAIN. I'm really getting tired of this. But what can I do?
On the other hand I'm selling my fbody oil pan, pick up tube and windage tray. Pm me some offers
Old 07-21-2012, 11:04 PM
  #446
bad6as's Avatar
The shop is making progress. He said the rear end is all done and is moving on to finish the front. The motor and mid plates from skinny kid race cars should get to him on Tuesday. With all these jy builds running great times I hope to be able to justifly why I had hke build this engine and get kicked out of a few tracks. This will be the last set up that I'm doing for a while and I'm going to make the best of it. I'm gonna be a dad come november so a good bit of time will be taken up by my lil girl
Old 07-29-2012, 10:44 PM
  #447
bad6as's Avatar
Rear tires now sitting a lot better then is was. I think he said 1.75 or 2" is what he took off both sides
Old 08-20-2012, 11:34 AM
  #448
GrannySShifting's Avatar
Ive thought this, but he said it!
Old 08-20-2012, 07:08 PM
  #449
Unstang's Avatar
Need more updates!
BTW...What springs do you have in your coil overs?
Old 08-21-2012, 05:53 PM
  #450
bad6as's Avatar
Originally Posted by Unstang
Need more updates!
Upr I think 14" 175lbs
Old 09-19-2012, 09:42 PM
  #451
bad6as's Avatar
UPDATE
NEW MOROSO OIL PAN AND CV PRODUCTS FILTER MOUNT
Old 09-20-2012, 06:49 PM
  #452
Rpayne41985's Avatar
looks good
Old 09-20-2012, 09:09 PM
  #453
LS1PUNK's Avatar
Damn Man!
U've been busy, looks good.
Old 09-22-2012, 07:01 AM
  #454
bad6as's Avatar
Thanks
Old 09-24-2012, 10:48 PM
  #455
Bloodbath's Avatar
looks good, shouldn't have any dramas with temps using that giant radiator, look forward to here the results with meth only, same road im going down.
Old 09-25-2012, 01:47 PM
  #456
bad6as's Avatar
That radiator is 31x19 lol paired w/ my taurs fan and volvo fan controler being trigged by the pcm I hope not to have any problems.
What's you set up? Pm me
Old 09-29-2012, 03:09 AM
  #457
LS1Notch92's Avatar
Wow...just read this whole thread!! Awesome build! Can't wait to see it run with the new setup!
Old 10-04-2012, 09:01 PM
  #458
bad6as's Avatar
i had to take it all apart once i got it back to add some fittings, gaskets and paint, wrap and reroute some things.
wolfe racecraft billet -12 drain and -6 feed, return has a cool screen, and a oring seal
boost leash II boost controler, herd good things about this so far.
shot of the exhaust. 5" steel in to dual 4" aluminum
4" charge pipe with bov flange and meth nozzles
charge pipe. custom meth nozzles
had to mill the thickness of the motor plate out of the alt bracket to keep the belt ligned up.
Old 10-04-2012, 09:08 PM
  #459
Unstang's Avatar
Wowzers, lots of new toys, looking good!
Old 10-04-2012, 09:35 PM
  #460
bad6as's Avatar
I can't put my iat sensor in the charge pipe because the 2nd meth nozzle is right be for the coupler so I thought about puting it in the center of the manifold underneith it. Thoughts?
Quick Reply: Single Turbo LS1 Notch Build *videos*
