One wire classic alternator
Old 02-04-2010, 06:03 PM
1970camaroRS's Avatar
Default One wire classic alternator
I'm running a carbureted LQ4 using the stock truck w/p, idler and crankshaft pulley. I have a powermaster one wire alternator I ran on my SBC and BBC setups in my car before. I was thinking about making my own bracket and putting a serpentine pulley on it. Where can I find a pulley to replace the stock v-belt pulley I had before, and is there anything I'm not thinking about that wont make this work? This is a very low budget build and my other alternative is to grab a bracket and alternator from the junkyard.
Old 02-04-2010, 06:51 PM
Mike52's Avatar
Why not call the people that made the alternator? Give Powermaster a call, they have the serpentine pulleys and they are great to deal with.
Old 02-04-2010, 07:49 PM
1A Dan's Avatar
Try Powemaster first, but you could always try your local part store as well. I remember swapping pulleys for customers all the time when I used to work for Advance. There may be one that's kicking around the back room unused.
Old 02-04-2010, 08:39 PM
Pop N Wood's Avatar
Take a walk through a pick and pull and grab a pulley from another alternator that has the same sized shaft.
I put a Denso alternator on mine because it was so much smaller than the GM ones. The one that had the lugs where I wanted it had a 3 or 4 rib pulley. I found a second alternator with the correct 5 rib pulley and grabbed that.
The parts can be mixed and matched. actually most pick and pulls have pallets full of core alternators near the entrance. You could probably find one in there with minimal walking.
Old 02-04-2010, 09:39 PM
I think I will pull the old pulley off, measure the shaft with a caliper and go junk yard hunting. I imagine the shaft is some sort of a standard diameter, but I can't seem to find any concrete info on it.
Quick Reply: One wire classic alternator
