LsX Mustang Guys with DYNATECH headers come in here!
Old 05-03-2010, 08:01 AM
  #81
key4's Avatar
^ Are you using the aje crossmember and what tranny is that? By the looks of the pics it looks easy to put exhaust on with that crossmember. If so I am ordering one today
Old 05-03-2010, 08:33 AM
  #82
Dickie-311's Avatar
pretty sure i should have my headers/steering shaft issue fixed i'll know more tonight
Old 05-03-2010, 08:23 PM
  #83
BlackTA96's Avatar
Finally got mine back from the coater, its in the car just not bolted up yet, I'll finish it up tomorrow and post some pics. So far everything is looking good.
What was your problem dickie?
Old 05-03-2010, 08:53 PM
  #84
Dickie-311's Avatar
What was your problem Dickie?
pretty much had to push the steering colum in to where the bolt that goes thru it is flush with the firewall
Old 05-11-2010, 04:43 PM
  #85
GM_GUY's Avatar
I broke down and ordered my headers today. Should be here on Thurs...I got a built glide ready to go in..my old headers for my th350 wasn't going to work.
Old 05-11-2010, 05:13 PM
  #86
LS88FoxBody's Avatar
Im having issues with mine also... err...
Old 05-17-2010, 07:47 PM
  #87
LSNotch's Avatar
I contacted Greg since this had me concerned ever since I read about the fitment issues. Good thing that my headers are still in the box. So I'm going to ship the driver's side header and they will take care of EVERYTHING! That's what I call customer service! Thumbs up for the Dynatech folks!
Old 07-25-2010, 06:59 PM
  #88
GM_GUY's Avatar
I just got around to installing mine...The driver sider header I can't even get into the engine bay. Did you guys have to take the motor mounts off and jack the engine up to get the drivers side on?
Old 07-25-2010, 07:19 PM
  #89
Gray86hatch's Avatar
you have to pull the steering shaft and the header goes in from the bottom.
Tim
Old 07-25-2010, 07:39 PM
  #90
danbap's Avatar
what he said ^
Old 07-25-2010, 07:40 PM
  #91
GM_GUY's Avatar
Tim
steering shaft is out. when i go to stab the header in from the bottom its hitting the firewall and the a-arm.
Old 07-25-2010, 07:44 PM
  #92
danbap's Avatar
mine slid right in from the bottom. had to twist and turn to get them in but it wasn't that bad. i had it sitting on jack stands.
Old 07-25-2010, 07:51 PM
  #93
GM_GUY's Avatar
what tranny do you have? mines sitting on jack stands...
Old 07-25-2010, 08:05 PM
  #94
Get the car higher.
Tim
Old 07-25-2010, 08:22 PM
  #95
danbap's Avatar
i have a th400, how is it hitting the a arm? you do have to have the car pretty high with my smaller pack of jack stands they are almost all the way out.
Old 07-25-2010, 08:47 PM
  #96
GM_GUY's Avatar
I have a glide
Ok I looked at it again. The second to the last tube hits the a-arm on the way up, and down towards the collector one of the tubes is hitting the oil filter. If I take out the oil filter I would have some more room.
Old 07-25-2010, 08:49 PM
  #97
GM_GUY's Avatar
Get the car higher.
Tim
I will try
Old 08-02-2010, 01:52 PM
  #98
GM_GUY's Avatar
I finally got the headers on..I also had to rerun a brake line.
Old 08-02-2010, 04:43 PM
  #99
I had to bend mine a little to get them away from the header. No big deal took 30 seconds.
Tim
Old 08-03-2010, 09:54 AM
  #100
GM_GUY's Avatar
Tim
I was having so much trouble with it clearing the motor mount part of the k-member. I wonder if my k-member is different from the newer ones. I did my swap in 2003-04...well the headers are on thats all that counts. All this trouble for a powerglide..
Quick Reply: LsX Mustang Guys with DYNATECH headers come in here!
