motor mount assist
Old 04-07-2010, 04:04 PM
brian g's Avatar
Default motor mount assist
Ok, I'm building my own motor mounts for an LS1 swap into an 83 Supra.
I just need a source/location for the tube and bushing portion of the mount, I've looked on E-bay and they only have 90$ universal set ups-this is not what I'm lookin for.
I just need the tube that has a bushing in it that hold the long mounting bolt.
I hope my description is clear.
Thanks in advance.
Old 04-07-2010, 10:29 PM
Mike52's Avatar
Brian, check out this link, then call D.W. and tell him what you're trying to accomplish, he has the parts and he will help you!! I used his parts for the engine mounts for the LS1 in my '32 Ford chassis.
Mike
Old 04-09-2010, 03:57 AM
brian g's Avatar
Thanks for the link Mike, unfortunately the only bushings that site shows are the type that go over a steel insert-that would be fine if there was a steel outer piece to go along with it.
I need a bushing that goes into a steel piece of short fairly thick wall tubing, so I can run a mounting bolt through the bushing after I've welded the exterior steel tubing to a motor mount...
Thanks for the input, that site has a lot of stuff.
Old 04-09-2010, 07:16 AM
99MUSTANG5.3L's Avatar
I was trying to come up with the same thing. I was thinking if I could find a set up like an aftermarket lower control arm bushing, that would be ideal.
No luck tho, I'll keep an eye on this thread, good luck!
Old 04-09-2010, 07:35 AM
lizeec's Avatar
Default Bushings
Try energysuspension.com they have a wide variety of bushings and mounts
Old 04-09-2010, 02:59 PM
brian g's Avatar
energysuspension.com has some sway bar bushings that are in the ballpark-but not quite what I'm looking for...the mounting would be a pita, but two of those would prob hold a single engine side up w/o a problem.
Click on the link below for an example, I'm looking for the bushings with an inner and outer steel sleeve-the rest I can fab up.
Thanks all.
http://img35.imageshack.us/img35/912...ounts20001.jpg
Actually, these might work!
http://www.energysuspension.com/univ...isolators.html
Old 04-09-2010, 05:49 PM
Mike52's Avatar
Brian, if you are trying to come up with the pieces to build your own engine mounts using the bushings in the above post, the link I gave you has those parts. You have to look thru their catalog for the individual pieces, they're not in a 'kit' for the LS engines.
Using the link, look at engine mount kit #WS2149 (this is for a SBC or BBC, not an LSx, but should be similar to what you're trying to do).
To make your mounts, find the following parts,
#10092- Outer tube for urethane bushing.....you'll need 2 @ $3.18 each
#214941-Lower tube.............................................. .2 @ $11.77 each
#214951-Upper tube.............................................. .2 @ $8.48 each
#1203- Urethane bushing ½......................................4 @ $2.47 each
#18908-Tube-inner, for urethane busings....................2 @ $4.44 each
You will also need the plates that bolt to the engine, these are easy to make from flat steel plate or you can get those from WS too.
Good luck with your project.
Mike
Old 04-10-2010, 06:19 AM
aknovaman's Avatar
http://www.autofab.com/bushings.htm
Old 04-10-2010, 08:59 AM
Jimbo1367's Avatar
Default bushing site
Originally Posted by aknovaman
good find!
Old 04-10-2010, 05:18 PM
Mike52's Avatar
good find!
I agree!!
Old 04-11-2010, 01:57 AM
brian g's Avatar
Thanks fella's!
Those should get me going.
Thanks again!
Old 12-21-2011, 01:17 AM
4u2trip's Avatar
Thanks! This is still helping people, great find.
Quick Reply: motor mount assist
