Ls1/t56 69 ta vert
#123
http://www.vintageair.com/2013catalo...Webpgs%206.pdf
#124
When you switch over to R123A you will need an evap unit that is set up for it and you will need a larger condenser to make it actually cool. When the auto manufacturers first swapped over to R123A, the air conditioners didn't cool as well. They finally figured out that they needed a different expansion valve and a bigger condenser to make it cool the same. If you are up north it might work well enough for you but here in the south it won't.
#125
I think he wants to use the entire GTO HVAC unit. If so, it shouldn't be a problem, packaging would be the only issue.
Sam
Sam
#126
Modern GM compressors are variable displacement... check out VA's info., they don't recommend it.
I used the Vintage air with the GM compressor from an 04 Van. It was Fixed. not variable. In the model number of the compressors there is either a V or F.
The vintage air unit i ran was always cold but just didnt move enough air to keep it cold.
With this swap im thinking of not only using the Evap unit from the GTO, but the Compressor as well as the BCM to run it all.
#127
I spent over 1300 on the vintage air system and was very disappointed. Ive paid that much for an entire car that had better AC.
Everything worked great, as long as it wasnt over 100-105. I always had my kids with me and they would sweat there butts off in the back seat.
With the GTO system i will be adding a rear air evap that i got out of an escalade rear air. It will be installed in the Trunk under the Package tray. Nothing much worse than looking at your toddlers with there cheeks red and sweat running down there face.
#131
Hey Sam, definitely an awesome build.
As far as the Vintage Air unit goes, and being you live in Texas, is it sufficient? Being I live in Las Vegas, I want to FREEZE in the middle of summer. BTW, I have a '69 Firebird with factory air that I was thinking of eliminating for the VA system, but now, I'm not so sure as I've seen a couple of people that weren't as happy with it.
#132
This is incredible. I saw a picture of your car online and after some searching I found this thread. The interior is jaw dropping, a true work of art. The talent that this website attracts blows me away. As soon as think I am pretty nifty with cars I see something like this and it's a completely separate ball game. Your build is very inspirational, thank you for taking the time and posting some pictures up here. I have so many questions out of curiosity about this car that I won't even begin to ask. Wouldn't want to bug you asking how you did every little thing. Very nice car, I totaled a 69 firebird when I was 16, have always wanted another one.
#133
Sam
#134
Sam
#135
Sam
I don't think I can top any of the compliments that you have received about this build, but just to say that reading through your blog I saw how inspiring it was to others contemplating the decision over that first step to bankrupcy lol. My personal favorite thing about this build is actually the fact that the engine bay is so uncluttered, no sloppy wiring harness, vacum pipes and the like, just nice and clean.
This build is a lot of what people are looking for these days I think, a modern interior and functionality but with the exterior lines of a bygone age of car designers who were given the liberty to design cars that spoke about them as designers and crators and created rivelries of the GTO fashion explosion era. sure they may not have been as mechanically 'safe' as they are these days with ABS, traction control, Brake force distribution etc.
But Who wouldn't want to be seen driving along the beach road in this!
#136
Sam
This build is a lot of what people are looking for these days I think, a modern interior and functionality but with the exterior lines of a bygone age of car designers who were given the liberty to design cars that spoke about them as designers and creators and created rivalries of the GTO fashion explosion era. sure they may not have been as mechanically 'safe' as they are these days with ABS, traction control, Brake force distribution etc.
Sam
#139
Hi-have you been going about your GTO conversion? I was going to ask same question on the evap/heater unit reuse. Starting on a 68 rag camaro 04 GTO convert
#140
I started on my non-stock(not and RS,SS Z) 68 camaro convertible with the driveline, dash, hvac, steering, wiper assembly etc from a 04 GTO.
Have a posting started..
https://camaroforums.com/forum/67-69...08/#post729438
