C4 corvette - 5.3 "LSX" engine swap project [PICS]
Old 03-09-2011, 11:31 PM
  #81
redmen031's Avatar
Correct it's the heat reflective tape.
Old 09-18-2011, 02:08 PM
  #82
JDMCRX's Avatar
very nice build man
Old 10-09-2011, 09:15 PM
  #83
redmen031's Avatar
I've been slacking and not updating the forums that much. I have this thread going on a different corvette site so let me catch everyone up to where i'm at!
Harness is done!
A few posts back I showed where the bolt that holds part of the brace that goes from the passenger side windshield to the frame extension was in the way when the header was installed. I removed this bolt and tack welded the bottom of the brace in place. There are still two more bolts on the top-side holding it on so this should be more than OK. Now my header clears!
Steam lines installed
New gaskets and foam installed
Old 10-09-2011, 09:17 PM
  #84
redmen031's Avatar
Time for some videos!
The first one is the result of us flooding the engine with fuel while trying to start it numerous times. Once the engine finally sparked it must have ignited that fuel and shot it out the exhaust ports. Also, there was no passenger side header installed at this time. No real damage was done, some burnt paint on the coil pack and black smoke on the plugs but that's really it.
http://www.youtube.com/watch?v=3We7Xls8AvY
And here she is finally running with open headers. I am very surprised at how smooth it ran, considering there's still a bunch of vacuum leaks, no O2 sensors hooked up and countless other things that still needs to be done. It was so loud it distorted the microphone a bit unfortunately.
http://www.youtube.com/watch?v=5FLmP4J0xFM
Old 10-09-2011, 09:20 PM
  #85
redmen031's Avatar
MORE VIDEOS!!!
Hooked up a bunch of temporary vacuum lines (silicone lines coming tomorrow) and I have the oil pressure gauge working. Reading about 60 PSI during idle. She runs MUCH smoother now.
Enjoy the videos!
http://www.youtube.com/watch?v=0VjpYYqgz5M
http://www.youtube.com/watch?v=_seAOxwNUSw
Old 10-09-2011, 09:22 PM
  #86
redmen031's Avatar
Ran into an issue. The bolt that holds the TV cable bracket to the trans snapped and it's not coming out. Had to drop the transmission in order to drill this bolt out. What a PITA! Anyway, the trans is back and I will post pictures as soon as I get my hard drive working on my computer....
Video of the first ride below!!!
http://www.youtube.com/watch?v=39oFjPUl4F4
Old 10-10-2011, 09:11 AM
  #87
Rikoshay's Avatar
Seems like it cranks over quite a bit until it finally starts. Any ideas why it's not firing up on the first crank???
Looks good otherwise. Congrats!
Old 10-10-2011, 09:35 AM
  #88
Trunion King
bene's Avatar
cam position sensor not hooked up? My car was like that hard to start up when I forgot to hook up my CPS.
Old 10-10-2011, 12:44 PM
  #89
dynodanmanda79's Avatar
Might be fuel pressure, and he may not have a check valve on his feed line.
Old 10-10-2011, 02:08 PM
  #90
redmen031's Avatar
Not sure why it's not catching right away. The cam position sensor is hooked up and the fuel pressure is steady at 57psi at the rails. Hopefully next weekend I will have more time to look into the issue. I will keep everyone updated.
Thanks for the comments!
Old 10-10-2011, 04:32 PM
  #91
jay7199's Avatar
glad to see someone finnish there c4 swap up. Make me want to do it to mine but i need money first haha
Old 10-11-2011, 12:20 PM
  #92
FirebirdTransAm's Avatar
I had a 96 6 speed C4 and decided that puting a LS1 in it was pointless when I was beating C5's and LS1 fbodys continually and put down higher numbers stock for stock. But I eventally sold the C4 for a C5, then sold the C5 for my WS6, and soon I will sell the fbody for a C4 again. Hopefully ZR1 or LT4 car.
Old 10-11-2011, 01:41 PM
  #93
ramairetransam's Avatar
does it need a case learn ? or is that not something on ls1's
Old 10-11-2011, 01:51 PM
  #94
LSCha0s's Avatar
Cool I didnt know you had one going here. Subscribed!
Old 11-05-2011, 11:56 PM
  #95
bigds1971Z28's Avatar
How did you hook up the tv cable and get the geometry correct
Old 11-06-2011, 12:03 AM
  #96
i have an 1985 and i have a 2003 5.3 im gathering parts. i want to use my stock 700R4 trans as well. however my experience with 700s and tv geometry has been a hard lesson learned on my many 3rd gen f bodies. until i spoke with the tci folks and found the corrector linkage. that said thats my only fear with my swap. plz let me know
Old 11-06-2011, 01:52 AM
  #97
LSCustoms's Avatar
great job
Old 11-06-2011, 09:49 PM
  #98
redmen031's Avatar
Got everything from these guys... http://www.tvmadeez.com/
Great people to work with and all their parts come with detailed instructions and phone support if needed. I'll try to post up some pictures of the TV cable adjustment once I recover all my images from my crashed hard drive
Old 11-06-2011, 10:06 PM
  #99
3.8redbird's Avatar
Originally Posted by claytonisbob
Man, there is a lot going on in that engine bay!
BTW, She looks enthused about your project.
What rims are these? How much do they weigh? They would look perfectly at home on my 85.
Old 11-06-2011, 10:17 PM
  #100
3xbrowncutty's Avatar
nice build!
Quick Reply: C4 corvette - 5.3 "LSX" engine swap project [PICS]
