Temp sensor question; ohms, and thread pitch.
Working on a '07 LQ4. Im trying to figure out if i can just get a temp sensor(same that the comp uses) and put it in the spot on the back of the passenger head and run it to my gauge. So, im wondering if someone has the ohms/temp values handy(to see if they will happen to match my jeep gauge) and i need to know if the threads are the same in both front driver head and the rear of the passenger. I know the passenger rear is a 12x1.5 so is the temp sensor for the comp the same? Any help would be great! And yes i tried and tried searching!
This is what the jeep gauge reads.
Temperature F ( C) Minimum Ohms Maximum Ohms
-40 (-40) .............. 291,490 .......... 381,710
-4 (-20) ............... 85,850 ........... 108,390
14 (-10) ............... 49,250 ............ 61,430
32 (0) ................. 29,330 ............ 35,990
50 (10) ................ 17,990 ............ 21,810
68 (20) ................ 11,370 ............ 13,610
77 (25) ................. 9120 ............. 10,880
86 (30) ................. 7370 ............... 8750
104 (40) ................ 4900 ............... 5750
122 (50) ................ 3330 ............... 3880
140 (60) ................ 2310 ............... 2670
158 (70) ................ 1630 ............... 1870
176 (80) ................ 1170 ............... 1340
194 (90) ................. 860 ................ 970
212 (100) ................ 640 ................ 720
230 (110) ................ 480 ................ 540
248 (120) ................ 370 ................ 410
