question: 700R4 connector on Belair w/327
Old 09-09-2010, 10:07 AM
Pony Exp.305's Avatar
Default question: 700R4 connector on Belair w/327
In one connector have 4 pins, what those pins goes to?
My friend has 1956 Chevy Belair with 327 engine. Can the connector change the transmission over to a one wire setup? Please tell me how I can..
Thanks for input.
Old 09-10-2010, 12:02 AM
classic79's Avatar
http://purplesagetradingpost.com/sum...o/700R4p2.html
see if this helps
Old 09-10-2010, 12:03 AM
Need inform relating the one-wire, it is for the lockup convertor switch. A single wire solenoid (12 volts)through the pressure switch to the self grounding solenoid. The switch must be a normally open type, closes with pressure.
please help or
Old 09-10-2010, 12:10 AM
Originally Posted by classic79
Thanks..I ll show it to my friend if he could do on it. I am not good with transmission job..
Quick Reply: question: 700R4 connector on Belair w/327
