question about fuel system in a ls1 converted fox body mustang
Im doing a ls1 conversion on a 93 mustang coupe and Im wondering how you guys set up your fuel systems on the mustangs using stock fuel tank with the intank pump? My mustnag already has a 255 lph intank pump I would like to use if I can. What will I need to do to make this fuel system work? I really didn't want to have to go to an after market pump like the a1000 yet or a sumped fuel tank. What are my options to make this work? Do they make a different assembly to drop into the tank or something? Car will probly make about 450 to the wheels with my heads, cam , and intake.
Check out my Photobucket, I modified the stock pick up assembly to accept -6 outlet, and a -5 return. I used the Corvette fuel filter. It was easy, the pick up came apart by melting the solder, replaced the tubes with brake line, soldered it in place. It was under $20.00
