3rd Gen Motor mounts
they might, but I know for sure that the steering rack in the v6 won't work. I'm doing a v6 to 5.3 swap right now I'm gathering parts still but I'll let you know once I start tearing it apart
try this place for help
http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
no, completely different. i have the spohn mounts in my car. had to notch the k member for clearance of my canton oil pan, but theres pans out now that i believe would make it a drop in affair
Two options
1) Stock LS1 Fbody engine mounts, Spohn K-member mounts in the V6 position on the K-member
2) Stock SBC mounts on the K-member, 1" setback adapter plates with stock V8 engine mounts
Non-setback mounts require a K-member notch, clearance is very tight, but passable with those combos
Your 89 steering parts are all retained unless you just want to go through the hassle of a R&P conversion
The TAcreations site isnt helpful because it covers 4th gen V6 to LS1 conversion where his 89 is a 3rd gen. This site has what he needs
http://www.thirdgen.org/techboard/lt...third-gen.html
Two options
I got the 1" set back mounts and the gmpp muscle car oil pan can I use the stock lower mounts from the v6 and just buy a set of poly mounts for the block ??? thanks in advance also any pics of this mount setup???
Well I already have the pan so hopefully I can make it work it is a race only car so the heater box etc is all out. So hopefully I can tuck it tight against the firewall and make it work if not I will cut the K member. I see the stock v6 mounts are to the rear of the k member is this the same as where the v8's are mounted???
here's one prior to yanking all the stock wiring and cleaning things up, but should give you an idea (you don't use the front-most lower bolt hole on the clamshells):
and a mess of other photos from the swap (kinda on hold due to weather and working 7 days a week...):
http://s191.photobucket.com/albums/z...am/LSx%20Swap/
I just looked on napa's website the v8 mounts are wider I can see the holes on my k member now $8 a side I will get two of them and then I have some sold clams from another sbc I have should work out
i've got the standard mounts, but i will definitely be changing over to the 1" setbacks when the LS1 goes in (round two). There's plenty of room back there and you won't have to notch the kmember like i already did. plus it will put your transmission output at the correct factory spot for the driveshaft (shouldn't have an issue with the non-setbacks, but doesn't hurt)
