pcm loaction 2004 gto and 99-02 f body
Old 11-07-2010, 07:06 PM
chevyboy91188's Avatar
Default pcm loaction 2004 gto and 99-02 f body
does anyone know what the difference is between the location of the pcm in an f-body vs the gto with ls1? I'm trying to figure out if the harnesses are the same dimensions.
Any input is appreciated. thanks
Old 11-07-2010, 07:41 PM
rotor vs. piston's Avatar
Not sure about the F-body, the GTO PCM sits between the drivers header and fender... amazing that it doesn't bake in there.
Old 11-07-2010, 07:49 PM
Bullitt4110's Avatar
They are on opposite sides, GTO is on the drivers side fender and the F-body is in the pass side fender.
Old 11-07-2010, 08:17 PM
you think that the pcm could be swapped sides? is the tail on the gto long enough to be moved to the passenger?
Old 11-07-2010, 08:43 PM
Not sure but I guess you could always extend the wires if needed.
Old 11-07-2010, 08:48 PM
Rick Speed's Avatar
The wires would be long enough but you may need to pull them out of all the tape and retape it in the direction you want.
Old 11-07-2010, 08:53 PM
sum guy's Avatar
The tail is pretty long on the GTO. I did a swap into a mustang and put the computor in the stock location which is the passenger kick panel.
