LS1 Cruise RPM
LS1 Cruise RPM
I am looking for some suggestions for the final cruise RPM for a stock LS1 / 4L60E combination. This is going to be in a 59 Bel Air so, weight is a consideration. After looking up some torque curves, I was thinking around 2200 @ 65mph. I am getting ready to select a diff gear ratio and had figuered some of you would have some suggestions based from prior experience.
Thanks,
Tim
Thanks,
Tim
My 54 has a 4l80 which is a slightly numerically higher OD with 26" tires & 3.00 rear will pull 8% grades without shifting out of OD while the cruise is on. these engines make good torque down low.
