What do 5G Camaro front end accessories line up with?
Old 02-21-2011, 12:44 PM
cjmatt's Avatar
Default What do 5G Camaro front end accessories line up with?
Do they line up with corvette accessory drives?
The drivers side water inlet will really help my turbos downpipe fit alot better but I run corvette accessories
Old 02-21-2011, 12:49 PM
deuce4935's Avatar
You can swap your Corvette's water pump pulley onto the Camaro water pump.
Old 02-21-2011, 01:52 PM
firstgenguy's Avatar
the waterpump lines up with the truck accessories.
Old 02-21-2011, 02:07 PM
cjmatt's Avatar
I want the Camaros pulley as its about half as wide. The earlier waterpumps like I currently run, have a wide pulley that was common between the corvette and ls1 camaro. corvette ran on the back half of the pulley and camaro on the front.
Not a chance. The truck stuff sticks out about 3x as much as the corvette stuff. I run a 5.3 the whole reason I took off the truck stuff was because it stuck out so far. The 2010 camaros have a NEW waterpump that looks like corvette offset. Small pulley on it just like the LS3 vettes. The difference is that instead of the inlet on the passenger side, its on the drivers.
Old 02-21-2011, 03:40 PM
-TheBandit-'s Avatar
First off, not all 5th gen Camaro accessories are the same. I have the 5th gen Camaro L99 accessories lining up with an '07 LY6 "truck" damper pulley, but the 5th gen LS3 accessories are shorter and will not line up (per frojoe's experience). More info in my build in the signature and frojoe's thread. The L99 comes in the automatic version (it has VVT & AFM/DOD). The LS3 comes in the manual version.
Old 02-21-2011, 10:02 PM
Mesquitebean's Avatar
I have a 2010 LS3 out of a Camaro. I also have an 07 6.0 VortecMax PU. They measure the same.
Old 02-21-2011, 11:52 PM
deuce4935's Avatar
So you want the Camaro water pump for the driver side inlet and thinner pulley? If thats the case then just buy the Camaro water pump and use spacers to line it up with the other accessories.
Old 04-02-2011, 12:32 PM
Jimbo1367's Avatar
IIRC... the newer Corvettte LS3 WP has the drivers outlet and short like the typical camaro4 WP
Old 09-18-2012, 03:30 AM
PHXSPEED's Avatar
ls3/6 speed camaro accessories do not line up with ls1 camaro accessories.
Quick Reply: What do 5G Camaro front end accessories line up with?
