Wiring Harness from Performance Systems Integration PSI
#82
?? For psi. I have 06 ls2 from a gto. I have the e40 ecm and the complete wire hardness that is set up for a t56. I want to keep it dbw. Dont have the pedal and also installing a 4l80e trans. Can you do any thinking for this set up. Going in a a-body. I looked @ your site notice you dont have e40 stand alone set up.
#83
I'm in a similar situation, I have a 5.3L out of an 04' Avalanche, and will be mating it to an 01' 4L80E. I'll be converting the injectors over to 80lb Deka's, LS6 intake and adding a 76mm turbo. I have the stock harness, but would be interested in a complete harness that would hook everything up.
#85
LS1Tech Sponsor
We do not support the E40 ECM as it was only used for 2 years. For our E40 customers, we can provide a harness that uses a 411 RED/BLUE pcm with a tac module and pedal. We can set it up for the 4L80E transmission as well. Please PM or give us a call at 732-691-6531 to discuss specifics.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
#86
LS1Tech Sponsor
We have a harness for your application in stock and ready to ship. Give us a call at 732-691-6531 to discuss. Thanks.
Jon
PSI
__________________
Ebay Store
Ebay Store
#88
Hey Jon, I am also interested in buying a harness from PSI but the only thing that is keeping me from doing so is the split loom. Is there any other covering that is offered from PSI? Thanks
#90
LS1Tech Sponsor
We do not currently offer any other covering, but if there is enough demand we would consider it. The intent of the split loom is to look factory. The braided snakeskin type looks cool, but traps dirt and grease. The heat shrink harnesses wouldn't be my first choice.
What other covering did you guys have in mind?
We have done a few harnesses without any loom, for custom builds as well.
__________________
Ebay Store
Ebay Store
#92
These harnesses look nice but if you havent seen the chasebays engine harnesses then check them out. They are made to your specs and can be made for any chassis wether it is a older 70's swapped chassis, a race chassis, or a modern g35 sedan they can make it.
Here is a picture of their LS2 CM1 engine harness
Here is a picture of their LS1 CM2 style that comes with a military grade cannon plug for quick disconnecting at the firewall. No fishing a engine harness through the fire wall when you dont have to.
Here are is a picture of their full mil spec harness with Raychem DR25 high heat and diesle fuel resistant heat shrink and individual sensor labeling.
#93
For anyone who wan'ts that nylon mesh sleeving for your personal projects Waytek sells the stuff.
Waytek Split Braided Loom Click Here
#94
Fatfreegto - Their nylon loom is low quality its not going to be a tight woven loom. You can pretty much see through the waytek loom when it is used on a engine harness.
#95
The link I posted is for a split nylon loom which will come in handy for someone who is simply trying to replace corrugated plastic loom or cover existing exposed wires. They do offer other expandable type loom which is a thicker material.
As for needing a business license, tax ID, and a buy in to place an order from them that is not true.
#98
Del City is another source for that stocks most of the same stuff as Waytek.
#99
Chasebay, yep, thats the one I had in mind. Thanks Dan.
TomM, I'm with you here:
"600 bucks for a harness with no fuse block or fuel pump relay....and I didn't see a provision for the 13 pin auto trans connector.........nice stuff, but I don't think so....
Convoluted tubing or not, looks to me like PSi is the better value for the dollar..."
About $100 bucks less and PSI's is pretty much plug & play, can't beat that!
#100
If you also look at the options they have options for the 4l60e but can do any other automatic trans as well.
Here are the options that have drop down menus that you choose according to your setup.
What Chassis?:
What Injectors?:
What Motor?:
What Transmission?:
Which ECM/ECU will you be using?:
Which Harness Model?:
