411 pcm pinout help
411 pcm pinout help
I recently bought a 5.3 from a 01 truck which has turned out the be the l59 flex fuel motor, the problem i have now run in to is the wiring was hacked up a little from the people just cutting wires when they pulled it and now i am having to splice it all back together. I found a great site that has really good pinout info here http://lt1swap.com/99-02_vortec_pcm.htm but some of my pinouts are different then this shows. It seems all the crank, cam, tps, iac, ect, and other sensors are the same pinouts as he posted in the link, but the injectors and coils are different. Your first thought is just match the color of wires from the pcm to each injector and coil, i wish it were that easy but the colors are different. Any help would be appreciated...im kind of at a stand still till i can get this figured out and i am by no shot a wiring expert lol.
