07 toyota x runner ls1 swap!!!
ok just as the head line states. i am in the proscess of putting a ls1 from a 2000 z28 in my 07 x runner. it came factory with a 4.0 v6 with m6. which was pretty quick for a v6 and a truck. but me being a gear head and loving chevy power i had to go for it.
1 started by pulling weak v6
as you can see i cut out stock mounts and welded in new
boxed in mounts for strength and cosmetics
the test fit....one of the tons of times in and out with eng to get everything to work, make sure to clear steering, headers fitment and yada yada yada.
yes its a 2wd it is the one with the body kit from factory.
here is the pass side mount. i have tons of room on both sides of the eng. but finding lt headers to clear everything is impossible. but i went with a set of pacesetter lt headers for a f body
had to fab up cross member for trans. wanted to use stock location because there is 2 supports that bolt from frame to x member, it kinda acts like sub frame connectors. i know it dont look the best but it is damn sure stong enough. whos gonna be under my truck....they will all be behind....fords at least.
as far as fuel goes, i had to upgrade pump in tank to a walbro 255. and ran all ss braided lines and used a c5 vette filter/regulator
my truck came drive by wire but the ls1 is dbc so i used lokar pedal and cable.
running 4l60e for now,using ss braided lines with a flexalight trans cooler. im kinda tired of changing gears all the time. the traffic where i live is crazy!!!
i know everything looks dirty so while i was waiting on ups to deliver more parts i started to do some spring cleaning. and painted eng. bay eng and some other things on my truck.
oil filter was a little to close to header for my likings so i relocated it up front, which also makes for a easy oil change. used -10an lines and fittings.
tapped oil bypass for auto meter gauge. also tapped water pump for gauge.
custom gauge pod.
for the shifter i am using a lokar floor mount in the stock location so it looks like a stick shift at first glance.
for exhaust i am running 3" true duals through a magnaflow x, then to a dual in dual out magnaflow muffler. i know the muffler has a x built in it but if i wanna ever change mufflers the x pipe will already be there. and turning down before rear axle. later on i plan on running out the back like a c6 vette. still waiting on the harness to get here. i ordered it form efi connection. going to have efi alchemy tune it when it is done. still need to have drive shaft made also. other than that its a slam dunk!!! hope you all enjoy.
X2 on a sweet swap, I've always liked the look of the X-Runner myself. That thing is going to haul ***. Theres so much room in that engine bay, do I see a turbo build in its future?
thanks, no turbos. not a big fan of them. its like a 2 stroke and to unpredictable to me. i like a supercharger if i go boosted. but plans are h/c/i/tb/stall/ bigger maf. not sure on cam yet prob a texas speed ms3. fast 102 intake. would really like input on cams and heads that will make good power and have a nice crisp lope like the ms3. also plan in a irs swap froma a vette or 03-04 cobra. i know i know a ford part in my truck....but we all know that the ford rear end is one of the best out there. but the powerplant SUCKS lol
i kinda figured i would catch hell on here for putting a ls1 in a toyota. but i see you guys actually like the truck.
no way man! this is sick. youre not the first lstaco on here, but i think the first xrunner
my friend has an x and a z06 and wants to sell the z because the trucks so fun. I keep telling him to do this
I gotta say, i wouldve kept w the 6 speed though and done a t56
