anybody use Kooks G8 mid length header/cat combo in a-body?
Old 03-29-2011, 05:00 AM
Goldhawg's Avatar
Default anybody use Kooks G8 mid length header/cat combo in a-body?
http://marylandspeed.com/kooks-mid-l...ty-p-2418.html
I'd like to go this route if they'd fit my 71 Cutlass conv. Anybody know?
Old 03-29-2011, 05:26 PM
bonecrrusher's Avatar
In my G8 - the engine is mounted kind of low - and it has a huge *** oil pan - 9.5 qts or something like that... makes for an expensive oil change.
I have SLP long tube headers on mine - and love the sound.
Can't really help you out fitting in an A-body though.
Old 03-29-2011, 08:33 PM
Goldhawg's Avatar
Well, if you can't even answer the question, at least give me something!!
Do you like them? Any dyno data? Would you do it again?
Old 03-29-2011, 08:43 PM
deuce4935's Avatar
Any particular reason for the G8 header instead of an A-body header?
Kooks makes them for the a-body swap http://www.kookscustomheaders.com/show.php?pid=867
Old 03-29-2011, 09:37 PM
Sad to say - the SLP headers and Corsa exhaust makes my G8 sound better then my vette.
I chassis dyno'd the Vette and the G8 back to back...
Vette put down 375/374 and the G8 put down 360/370.
Not bad for stock tunes on both....
Old 03-30-2011, 05:22 AM
Goldhawg's Avatar
Yes. I don't like tube headers hanging low. I hate hitting speed bumps. Further, I want a cat. I've had TPI/LT1 engines in the cutlass the last 20 years and w/o a cat the exhaust really stinks. I've been told modern free flowing cats don't cost much power wise so I want to install one. I was thinking of trying DT or JBA shorty headers for a 2010 camaro and the JBA catted midpipes, but thinking this might do even better if it would clear, given the larger tubes.
Old 03-30-2011, 05:42 AM
Goldhawg's Avatar
For anyone else looking, I found this dyno data on these installed here:
https://ls1tech.com/forums/pontiac-g...m-results.html
looks pretty good; not too far from LT power output and a fair amount better than other shorty headers.
Old 03-30-2011, 02:26 PM
BanditDave's Avatar
Looking at the pic, that first tube on both sides - Cyl 1 and 2 - both look to be hanging too low and will hit the crossmember. You may be able to get away with a notch.
I am actually using 98-02 F body Pacesetters...I will have to redirect the drivers side slightly but they literally load in from the bottom with NO effort at all. Fits perfect in both cases.
Quick Reply: anybody use Kooks G8 mid length header/cat combo in a-body?
