V6 Silverado 5.3 Swap
Old 04-07-2011, 07:28 AM
mojo1865's Avatar
Default V6 Silverado 5.3 Swap
I've been looking for this, but can't seem to find the answer anywhere! What I have is a 99 silverado with a 4.3 V6. I'm wanting to swap the V6 out with a 5.3. What I can't figure out is, if I have all the pieces (5.3, harness, PCM, non-swapable hanging parts), is this basically a "plug and play" swap?
I read somewhere that the V6 PCM is the same...would simply need re-flashed. However, the PCM is actually an older style V6 ECM (four connections to the harness). If I got an engine with a matching PCM, would the rest of the truck's wiring work with this?
The truck is a "new body style," not one of the older body style trucks made in 1999.
Thanks!
Mojo
Old 04-07-2011, 11:42 AM
kdavis's Avatar
I think you will find more info on performance trucks
Old 04-07-2011, 03:00 PM
the_merv's Avatar
You will need a V8 PCM..aswell as V8 Wiring..I dont see if you got a V8 Fuse Box with it why it wouldnt be a plug n play..
Quick Reply: V6 Silverado 5.3 Swap
