Autometer speedometer, One input terminal?
Old Feb 19, 2004 | 07:46 PM
Flyman's Avatar
Default Autometer speedometer, One input terminal?
I understand by reading other post's that when hooking up an electronic Autometer speedometer that i need to "splice" into the wire comming off the tranny speed sensor but the sensor has two wires coming off of it and I only have one input on the speedometer, do i just splice into one wire? and if so, does it mater witch one? and what is the output terminal used for?
Thanks
Old Feb 19, 2004 | 10:52 PM
Lesrace82's Avatar
You use the VSS signal into the PCM. You dont use the output at all on the speedometer.
Old Feb 19, 2004 | 11:28 PM
Flyman's Avatar
do you just pick one of the two wires on the vss and splice it and run a wire to the one input on the speedometer?
Old Feb 20, 2004 | 03:18 PM
Lesrace82's Avatar
no find a pinout sheet of the PCM, you splice into the VSS input going to the PCM
Old Feb 24, 2004 | 11:51 AM
67ls1CamaroProject's Avatar
One is signal and the other is signal ground. Must use signal. I believe it was the purple wire. But, you better look it up because my memory is short.
Old Feb 24, 2004 | 12:48 PM
crainholio's Avatar
On my '01 LS1, the PCM already had a VSS 4K pulse/mile output. It was on either C220 or C230 I believe. If the LS1 you're using has this, just bring it to the Autometer speedo and you're done.
Old Feb 25, 2004 | 08:50 PM
This will absolutely not work with an Autometer Speedo. That 4k pulse per mile is a square wave and the Autometer will only work with the sine wave signal directly from the VSS. Also, do not cut the VSS signal wire and then wire the "Sig Out" from the Autometer to the PCM. This will screw up the PCM and cause a VSS error code. YOU MUST splice into the VSS and bring a wire to the Autometer and don't interput the PCM signal. I know because I wired it this way first and the Speedo did work but the vehicle speed was always zero mph causing other issues, mainly coming to a stop and nearly stalling.
Old Feb 26, 2004 | 06:28 AM
crainholio's Avatar
Thanks for the correction, my apologies for posting bad data...the Helms specs sure look like that should work but I didn't catch the part about the PCM output being square-wave.
 Michael S. Palmer
Old Feb 26, 2004 | 09:55 AM
Lesrace82's Avatar
How many people are using the autometer speedometer with an automatic? I had it on my car and ended uprunning into alot of problems, had to put a 2K ohm resister inline to the speedo. Trans wouldn't shift out of first sith out it. Just wondering if im the only one that had that problem.
Old Feb 26, 2004 | 10:59 PM
Flyman's Avatar
how did you have it hooked up?
I am hooking my autometer up to a 4L60E.
Old Feb 27, 2004 | 06:51 AM
I would bet that you did what I did the first time (followed Autometer's Directions ) If you just splice into the line like I mentioned I think your problem would be solved. I had a similar problem with mine in that it wouldn't let me shift into reverse, the solenoid for reverse lockout wasn't activating because of my bogus VSS signal. I bet your VSS signal to the PCM was also bogus. This would indicate to the PCM an incorrect speed and hence the tranny doesn't think it is time to shift. Just a guess as mine is a T56.
Did you ever hook up a scanner to see the vehicle speed? Mine was always zero!
Old May 5, 2008 | 08:02 PM
WS-6_2002's Avatar
I am trying to install an autometer speedo now too. I want to get this right the first time so please let me know if I'm understanding this wrong. I need to connect a wire from the speedo and splice it into the VSS signal wire? In the wiring diagram I have it shows that the two wire coming out of the sensor are labled VSS high and low signals. Which one should I use? Thanks for any help you can give me.
Old May 6, 2008 | 04:43 AM
67pete's Avatar
I ran both wires twisted to the Speedometer to cut down on the RFI. "High" is the signal and "Low" is the ground / shield. Just tie them in parallel with the ECM.
Old May 6, 2008 | 04:57 AM
LS1MCSS's Avatar
If you're using a 99-02 LS1 pcm, hook C2, pin 50 to the signal connection of the speedometer. Ground the speedometer to the body and calibrate it per the Autometer instructions and it will work correctly.
Old May 6, 2008 | 04:12 PM
WS-6_2002's Avatar
I'm using a 3 3/8cobalt guage. Can I run that one in series or do I have to tap into the wires? I've heard to not run the 4l60e in series. Is that true?
Old May 7, 2008 | 04:20 AM
67pete's Avatar
Basically need to follow the meter's instruction, but this is what I did with my Autometer........
Old May 7, 2008 | 08:55 AM
Rodder's Avatar
No, he's right. Autometer speedos work fine with square wave. My Autometer UltraLite II works perfectly off the 4K PPM square wave coming from C220-K with a 99 Fbody PCM & harness. And by perfectly I mean that I've got over 1000 miles on it without a single problem, and I've verified my calibration against my GPS. In fact, if you read the AutoMeter instructions (http://www.autometer.com/download_instruction/1029A.pdf), you'll see this statement:
The speedometer is designed to operate with an electrical speed
sender. The speed senders signal pulse range must be between
500 and 400,000 pulses/mile. Any speed sender or electronic
module that meets the following two conditions can be used:
• Pulse range generated proportional to the vehicle speed
• Output within the voltage ranges listed below:
2.0 to 16V peak (Square Wave), 3 wire
2.0 to 120V peak to peak (Sine Wave), 2 wire
And if you look up Autometer's own 5291 & 5292 speedo senders, (http://www.autometer.com/download_instruction/0776A.pdf), you'll see that they are a 16 pulse per rev square wave.
Old Sep 23, 2008 | 03:00 AM
loweredd's Avatar
Rodder, I was going to use my C220 wire also......which spot did you hook it to? I have the Autometer instructions here, but they say to hook to the SIG terminal and then run a wire from the OUT terminal to the computer..>???
Old Sep 23, 2008 | 07:16 AM
stealth71's Avatar
The wire from the PCM is an output. Just hook it to the SIG wire on the speedo.
Old Sep 23, 2008 | 08:33 AM
Rodder's Avatar
The autometer instructions assume you are tapping into the speed sensor somewhere inbetween the trans and the PCM. You aren't doing that--you're getting a speed signal produced by the PCM itself. Just hook C220K to the SIG terminal on the speedoand it'll work .
