New lsx swap fox body manifold choice
I am wondering also on your truck pan. How much did you cut off and what did you use for a windage tray/oil pickup???
This thread also makes a guy wonder if these headers would work on a budget build?
http://cgi.ebay.com/ebaymotors/CAMAR...Q5fAccessories
I would have to measure it... there is a line on the front of the pan that we used to cut the pan...
may not need to cut dips stick...it didnt go all the way to the bottom of the pan and we are still working on pick up tube
oh added some more parts to the build
#36
Hot side is all custom built at my work.. All out performance. My boss steve fabed it. It's not completely mounted but my ecu and drive by wire module will be were my a/c and blower motor use to be
#38
i was able to use 2010 camaro exhaust manifolds and they fit great.. I figured if the stock manifolds fit then so will these
http://www.amazon.com/PaceSetter-70-.../dp/B003X6FUVW
headers for a LSX swap might only be 210 bucks now...
