Trans Dapt swap mounts...1 inch set bac only?
Old 05-01-2011, 04:01 PM
brian.harmon1974's Avatar
Default Trans Dapt swap mounts...1 inch set bac only?
I'm finally getting some money and am looking for cheap swap mounts and found trans dapt, has anyone used them? also why are they only in 1inch set back? is that what i need to put the 5.3 in a stock SBC location?
Old 05-01-2011, 05:27 PM
ishmael's Avatar
One inch back is for the stock sbc location. I don't know about the transdapt plates but I would consider your headers and trans crossmember before purchasing plates. They all have to work together.
Old 05-01-2011, 05:58 PM
deuce4935's Avatar
The 1" setback plates are suppose to allow you to bolt the engine and trans together while keeping the trans in its stock location and prevent you from having to modify the drive shaft length, the engine wont be in its stock position, hence the 1" setback.
Old 05-02-2011, 08:33 AM
ok thanks thats what i was looking for, the crossmember is the stock piece that was moved back for the 700r4 i installed. im going to use stock manifolds for now, like i said as cheaply as possible
Quick Reply: Trans Dapt swap mounts...1 inch set bac only?
