ls into c4 corvette?
I've contacted several shops about putting an ls engine into my C4 Corvette. No one says no, but I haven't been able to move forward to a serious planning/budgeting phase.
Can anyone suggest a shop within a 1 or 2 day drive of the San Jose area that
A) is capable of doing this, or better yet, has done it?
B) is interested enough to participate in the planning/budget phase?
This isn't a trivial swap, but is doable. I'm doing my homework & believe I have a reasonable idea of the gross budget. I just need someone who will take me seriously & work with me to hammer out the details and get 'er done.
Yikes! Googled their shop, clicked on the link, virus protection went nuts. Now internet explorer doesn't work properly & I'm waiting on a call back from my technical support folks.
I've also purchased several books on LS swaps but none of them mention C4's, as far as I can tell from an initial look.
I've spent the last couple of hours running malware and virus scans. I've got iexplorer working again but am still going to have to have my tech guys clean up my computer. I'm a bit leary of tracking down the last shop mentioned after that, at least on the web.
www.yatesefi.com Check out the build they did on the c4 vette!
P.S. I sent them a message to get their take on this, just out of curiosity.
Assuming my virus problems had more to do with my computer than their web site (and trusting on better virus protection on my work computer) I visited Brea Auto Electrics web site & spoke with them today.
They were very generous with their time & sound like a good shop. I learned a few things about CA smog requirements that I hadn't picked up yet (for example can't use my existing '87 vintage Cats!). Their rough estimate was a real reality check for my budget, though. That's ok...it just reinforces the point of this thread, if this is going to happen the budget has to be worked through in detail before I pull the trigger & I need to find a shop that will help do that.
Please keep your recommendations coming.
I can't help with the smog **** but here is my thread, hope it helps.
There are a lot of things that will nickle and dime you to death add 1k for that. You might only spend $300 but be prepared.
BTW... what year is your car?
https://ls1tech.com/forums/conversio...e-my-swap.html
I've been subscribing to your threads on the various forums.
I have an '87. It's running fine so I can be patient looking for a shop to work with. I'm definitely trying to do two things "wrong"---pay someone else to do the swap, and comply with the CA smog requirements. I realise there's a cost adder to both of these choices & am willing to pay it, to a point. I think the key will be a shop with C4 swap experience who's prepared to offer this as a turnkey service. Several seem to be close, but not there yet. I may just do a couple more cosmetic things (paint, carpet, weather stripping...) and wait to see what develops.
The folks I talked to yesterday encouraged me to supercharge. I expressed concern about the bottom end of my engine (58000 miles) & they said 'so what, those engines are cheap, if it fails replace it'. I could go through several engines for what some folks are asking for the LS swap so there may be something to this.
Hi,
5.3s are almost as cheap as 350s make the same or better power and get better fuel economy.
Going for an aluminum block or big cubes changes that but an iron truck engine is easily doable on the cheap.
Just an update:
I'm starting to get real quotes and am going to have to make a decision soon. So far the numbers are a bit higher than I'd hoped, but that's because I'm starting to lean toward the EROD LS3 swap as the easiest way to satisfy CA emissions.
Thanks again for your suggestions.
Just an update:
True. The quotes I'm getting are close to what I've budgeted but I am still losing some sleep trying to rationalize the expense.
One thing to keep in mind is that I'm replacing a fairly low mileage engine (58K) and don't want to swap in a used engine with higher mileage. This means finding a low mileage engine or overhauling a higer mileage one, both of which add to the costs. With the EROD I get a new engine (with warantee) for only about $3K more than the used one would cost (plus missing accesories).
If I could do it myself, my cost structure would be quite different, but I just don't have the time or energy (and am many years away from high school auto shop).
If the costs line up I'll do it, if not I'll put the money into paint and interior restoration and wait, the L98 will last a while.
