Alternator and Starter wiring help...LS1
Old 05-13-2011, 08:57 PM
yesaCSpencer's Avatar
Default Alternator and Starter wiring help...LS1
What do I need to do to wire my ls1 alternator and starter so they will work? I know its a blunt question but I need help. The rest of the wiring is already done; this is just the last thing I need to do before it runs. Its in a '95 240sx
Old 05-13-2011, 09:13 PM
deuce4935's Avatar
Is your ls1 harness missing the the plug that goes into the rear of the alternator? What about the wires that go down to the starter?
Old 05-13-2011, 10:51 PM
It has the plug the goes to the alternator, but thats it. Does it need anything else? And there are no wires that go to the starter
Old 05-14-2011, 06:42 AM
LS88FoxBody's Avatar
You need the plug that goes to the alternator , and the Wire that goes to your battery . That is the nut on the back. You can either run it to your starter terminal which your positive wire connects to , or you can run it to the battery. The S terminal on the starter gets 12v when you crank the key. Find the wire that went to your old starter ,and your in business.
Old 05-14-2011, 09:30 AM
71ANTICARB's Avatar
Like they said with my Chevelle I ran the factory wiring to the starter and a cable from the alt to the battery and then plug in the wire from the pcm.
Old 05-14-2011, 10:01 AM
Pop N Wood's Avatar
Use the same alternator power wire and starter wires that your stock SX used. Hook them up just the same way.
Old 05-15-2011, 06:08 PM
How big does the power wire from the alternator need to be? I have a lot of 16ga. wire laying around but I dont know if that is big enough
Old 05-15-2011, 06:19 PM
Pocket's Avatar
8 ga or larger for the output lug depending on amperage. 18-20 ga for the harness connector
Old 05-15-2011, 06:47 PM
71ANTICARB's Avatar
Runnin 6ga for my charging wire. But more because I had it and less because I needed it. Remember its better to be too big than too small... that's what she said.
Quick Reply: Alternator and Starter wiring help...LS1
