L92/VVT in C4 vette LS/T56 swap
Old 09-15-2012, 06:27 PM
  #81
85MikeTPI's Avatar
Some more testing with the VSS:
Nothing I did with my 2007 Escalade L92 VVT OS would put my scanner at 158mph, so I can't be of any help with those having that problem.
The VSS output pin of the E38 (X1-57) would give me a 128Kppm, but no settings in HPT would scale that down, only up. I had that wire feeding the 4Kppm signal wire for the C4 (normally comes from the C4 ECM) and it was read correctly, but with no capability to scale it down, it was useless. A Dakota Digital SGI-5 box could be used to scale it down, but that cost $, has additional wiring and PWR/GND connections and adds another point of failure IMHO..
Code:
The HPT Speedo setting for "Vehicle Speed Output" doesn't appear
to an output, but instead is an input setting for the TOS (X1-71) pin.  This
can be set to:
       - Disabled: The E38 will look for a Discrete Sine Wave VSS signal on
                        both VSS hi (X1-71) and VSS lo (X1-72).  The T56 VSS
                       drove this setup correct but the VSS wasn't strong enough
                       to split between both ECMs.
       - RepTOS: The E38 will look for a single wire digital VSS signal on just
                       the TOS (X1-71) pin as if it was coming from a TCM.
       - Serial:    The ECM will ignore X1-71 and pull a VSS signal from the
                       CAN bus
So for my "modern" car having an ECM already connected and piggybacked, I have the T56 (~45,500ppm) sine wave VSS signal feeding the C4 ECM. It outputs a 4Kppm square wave that feeds all of the car's other systems (including Speedo) and I tapped that signal and back fed into the E38 TOS pin. I enabled RepTOS as above and scaled the HPT "VSS Output Pulse per" setting to 45,000. The car now reads a valid (but wrong) MPH on the speedo as well as a valid and correct value on the scanner..
I still need to dig out my old PROM burning equipment and reprogram the C4 ECM for a 45,500ppm VSS to get the speedo scaled correctly, then I can also go back to HPT and should be able to set the "VSS Output Pulse per" parameter to 4000 ppm.
Old 09-15-2012, 08:57 PM
  #82
1989GTA's Avatar
Good news. Sounds like you have the problem identified and you are now working through the solutions.
Old 09-16-2012, 12:00 PM
  #83
85MikeTPI's Avatar
verified this today. 92 vette prom ($DA2) programmed with a 46,000 ppm Road Speed Constant and a divide-by-11 (96) Instrument Panel Divisor setting. HPT VSS Output Pulse per set to 4000ppm and now both the dash speedo and HPT scanner are showing 9-11mph while idling in 1st gear on jack stands..
Onward..
Old 09-27-2012, 06:37 PM
  #84
85MikeTPI's Avatar
Finishing all of the minutia of the swap. All new plug wires, hoses, etc. putting on the covers, panels, etc. Exhaust assembly begins this week.
2007 Escalade L92 PCM wiring diagrams in case anyone looks here instead of searching
2007 Cadillac Escallade ESV 6.2 L92 Vin 8.pdf
DBW Pedal, stock clutch&brake pedals, kick panels, and OBD-II connector
L92/VVT in C4 vette LS/T56 swap-102_1503.jpg
Mounting of B&B axle-back exhaust and Spare Tire carrier
L92/VVT in C4 vette LS/T56 swap-102_1508.jpg
GTO 17" Spare tire
L92/VVT in C4 vette LS/T56 swap-img_0002.jpg
Axle-back, spare tire, carrier
L92/VVT in C4 vette LS/T56 swap-102_1510.jpg
Old 10-15-2012, 12:12 PM
  #85
85MikeTPI's Avatar
Header connections, Random Tech metal matrix bullet cats, and Magnaflow X-pipe
L92/VVT in C4 vette LS/T56 swap-img_0034.jpg
Attached to Billy Boat axle-back full 3inch dual exhaust
L92/VVT in C4 vette LS/T56 swap-img_0036.jpg
Removable exhaust section all fully welded
L92/VVT in C4 vette LS/T56 swap-img_0042.jpg
I have almost 300mi on the build right now after taking it
down to the Ocean City MD Corvette Cruise. Everything survived and tuning and small patch jobs continue to refine it.
Car runs strong in the occasional sub-4000rpm jaunt. I hope to have it at the track for a shake-down run and then the dyno soon after and before Winter sets in.
Old 10-15-2012, 12:17 PM
  #86
LSCha0s's Avatar
Great progress, it sounds mean .. I can't wait to get mine finished and be able to drive it.
Old 10-15-2012, 04:04 PM
  #87
TPI TERROR's Avatar
great progress and good info. that bb exhaust sounds great for the set up
Old 10-20-2012, 12:28 AM
  #88
1bigoldman's Avatar
Just finished reading this thread. Nice work.
I did not see mentioned who's headers you are using. What PN? Do you have pics of them?
Thanks
Old 10-20-2012, 06:22 AM
  #89
85MikeTPI's Avatar
Thanks
http://www.melroseheaders.com/produc...ers/C4_LSx.php
Melrose is the only one making C4 LS swap headers AFAIK.
http://www.eecis.udel.edu/~davis/z28...aders-mtrmnts/
Old 11-08-2012, 03:15 PM
  #90
-TheBandit-'s Avatar
E38 L92 ECM and '97 MonteCarlo/Lumina underhood fuse&relay box mount in front nose of vette
Attachment 355359
2003 Impala underhood fusebox, modified for L92 engine harness circuits. Engine harness connections extended from the firewall area, to area in front of wheel.
Attachment 367760
Attachment 367764
Attachment 367761
Not a bad looking fuse block. Did it have all the fuses & relays you needed? And which was it, '97 MonteCarlo/Lumina or 2003 Impala?
Old 11-08-2012, 03:16 PM
  #91
- ATI damper from 2010 Camaro
Attachment 334455
What made you go to the ATI damper? Those things are so pricey!
There's some really interesting reading on dampers & timing chains in this thread: https://ls1tech.com/forums/generatio...n-failure.html
Old 11-08-2012, 04:16 PM
  #92
85MikeTPI's Avatar
The eBay auction listed it as an MC/Lumina, but when I got it and started looking around, I found it described as a '03 imp.
http://www.ebay.com/itm/03-IMPALA-FU...item25776a6c6e
Is the same. I took apart the 2 boxes and made one full box.
But then again I do see them referenced as MC/Lumina too, so GM may have used then in other apps..
http://www.ebay.com/itm/95-96-97-98-...-/290771217548
Had all I needed and I even used one of the extra relays for the 3 relay fan circuit the E38 wanted.
Old 11-08-2012, 04:21 PM
  #93
85MikeTPI's Avatar
The choices seemed to be stock, slp/power bond/etc non SFI, and the ati or fluid damper SFI. No way I was putting stock on after seeing all the rubber separated dampers. The non SFI models were pricey, and didn't look much better than stock, and then the SFI. Since the vette ls3 ati's were $100 more than the L99, I rationalized it that I was $100 ahead already..
Old 11-08-2012, 04:25 PM
  #94
At the moment I didn't have plans to change mine from stock, but I'll search around for more info. Do you know if the separating stock dampers are more common on manual applications or is there a specific failure cause?
I don't see those things listed anywhere for less than $350. Ouch.
Old 11-08-2012, 04:56 PM
  #95
85MikeTPI's Avatar
Most of the ones I know personally of were manual cars, but I mostly hang around manual trans cars.. . My application is road course and autox, which seems to be harder on the damper/chain also.
The ati is expensive, but so is a broken valvetrain... I tend to throw $ at something I'm likely to stress..
Old 11-21-2012, 12:47 PM
  #96
I worry a bit less about valvetrain with the Katech chain, but what else happens when a stock damper fails?
Old 11-21-2012, 07:04 PM
  #97
85MikeTPI's Avatar
Depends. Most are caught when the vibrations get so bad, others, take out the hood and/or radiator, and the worst case ive seen one catch and lock up the engine and spin the car out into a wall... YMMV
Old 11-21-2012, 09:00 PM
  #98
cam
cam's Avatar
Mine just fell to the bottom of the pan where it still is.... and might stay if I cant fish it out. As for the Power Bond Pulley? SFI allll they way its a good'r for the dough imo
I didnt notcie anything different driving it so I cant say when the tensioner failed I just thought to check it while I had the car in the shop and working on it. Costs me nothing but a couple of hours of time as I re-use the gaskets and the crank bolt is an ARP. Of course that was until I inspected the phaser and released the spring *uff* Anyways new phaser supposed to be here tomorrow
Old 11-21-2012, 10:48 PM
  #99
85MikeTPI's Avatar
Clint was asking about the stock damper failing, but
The tensioner is something else to watch for. I think
It's been noted that the Katech chain is tighter and a
Broken tensioner probably won't affect the motor as long
As the pieces don't like you're hoping.. (and I would hope
Too)
Old 11-21-2012, 11:18 PM
  #100
cam
cam's Avatar
Oh yeah, doh. nm
Quick Reply: L92/VVT in C4 vette LS/T56 swap
