time for a new project: 1978 malibu LS swap
Old 06-11-2011, 02:53 PM
lt4malibu's Avatar
Default time for a new project: 1978 malibu LS swap *back from the dead update on page 4*
the car:
'78 Malibu Landau coupe, originally built by my friends father back in the late 80's it pretty much retained most of the factory appearance(aside from removing the landau vinyl top) - when the car was built, there wasn't much out there for these cars - so he got a ford 9 inch from a Versailles and made it fit with hotchkis upper and lower control arms, strange 3-way shocks, and the rest of the factory 6 cylinder Malibu suspension. it had many Small blocks and th350 for most of its life, and was bracket raced every saturday and sunday until he sold the car to a neighbor back in 1995. fast forward a few years my buddy buys the car back after it had been abused and neglected for 10 years. he put a steel headed 355 in it with a 'Glide and went bracket racing. then he had to put it away due to changing jobs, sold the motor and it sat in storage for 4 years. ive been trying to convince him the LS series engine was the way to go for an affordable motor with good power and finally he gave in. now its being resurrected and being taken from a race car back to a drivable street car.
i picked the car up about a month ago from storage and brought it back to my garage. i had been stockpiling parts for a while, he's on a budget and the car needs some updating(has an old STEEL 6pt. rollbar, plastic fuel cell in the trunk, among many other things that it needs so its going to the chassis shop in a few weeks to get a new 10pt cage) the plan is to get it running and driving for around $3500 and we're doing pretty good so far. picked up a stock LS1 from a 2000 camaro with 80k on it for $1500 complete with harness, accessories, and a bunch of other stuff which we turned around and sold for $650 since its getting a carb. the powerglide is gonna stay for now and the engine is gonna stay stock except for a edelbrock victor intake.
today i started mocking stuff up, using a set of transdapt 1inch set black plates i set the motor in and bolted up a set of pace setter headers for a 98-02 f-body - it all fits perfect! even the camaro oil pan clears the crossmember! i plan to use a BMR alternator bracket for the F-body alternator (the car has a manual steering box so and there's plenty of room)
ill keep updating as i make progress, but here's some pictures for now:
this was taken probably 6 or 7 years ago back in its bracket racing glory days
adapter plates bolted up
at first i tried the Moroso solid motor mounts that were on the old SBC
this side is good...
this side not so much...
yanked it back out
bolted up the transdapt mounts that come with the kit
fits like a glove
F-body oil pan even clears the stock crossmember, which is most likely gonna get cut out and have a tube installed to save some weight, but good to know it clears without modification
98-02 F-body pace setter headers
drivers side went in from underneath
passenger side went in from up top
the #2 header tube is REALLY close to the frame, its not touching but i think i might gently flatten it slightly to gain a little clearance just in case, also have to re-route the battery cable obviously.
looks like it belongs there, not bad for a days work.
***back from the dead update on page 3***
Old 06-11-2011, 05:06 PM
350SS's Avatar
looks good so far...subscribing
Old 06-12-2011, 03:24 PM
ponjohn's Avatar
Looks great, good luck.
Love the color.
Old 06-12-2011, 07:52 PM
deuce4935's Avatar
Good to see some pics with detailed instructions. Btw, did the powerglide stay in its original position or was it repositioned?
Old 06-12-2011, 08:48 PM
lt4malibu's Avatar
still in its original position that it was with the SBC.
Old 06-12-2011, 09:39 PM
zipster's Avatar
I love those cars. My first car was a 1978 Malibu, 305v8 Th200, it was fast! Well, when you are 16 and your car burns rubber you think its fast. I had 6 Malibus total with that body style.
Its good to know the headers worked. A little dimple here and there is ok.
Nice car.
Old 06-12-2011, 09:53 PM
Bowtiedford's Avatar
good luck, looks great
Old 06-12-2011, 09:55 PM
skimms98's Avatar
love it...keep us posted!
Old 06-13-2011, 10:04 AM
lt4malibu's Avatar
thanks for the compliments!
i should have the intake, waterpump, alternator bracket, flexplate/adapter, and converter this week. gotta go through the carb he has since its been sitting for 4 years but im gonna try to fire it up next weekend if possible
Old 06-21-2011, 02:30 PM
deuce4935's Avatar
Any updates?
Old 06-21-2011, 02:45 PM
lt4malibu's Avatar
depends if UPS stops by today
i did bolt on the electric waterpump and BMR alternator bracket this weekend. as soon as i put some more stuff on i will post pictures of how it all fits.
Old 06-22-2011, 08:10 PM
lt4malibu's Avatar
well the intake showed up today, along with the flexplate and MSD box. engine will come back out this weekend so i can bolt the flexplate up and put the converter in.
this is how the alternator fits with the BMR alternator bracket, its close but clears the steering shaft and box (might not clear a car with power steering though)
and the converter with the "adapter"
Old 06-22-2011, 08:28 PM
deuce4935's Avatar
What t/c adapter is that? Looks like a pretty neat piece to have for those using the older style transmissions. The other option is to use a fleplate from a 6.0 truck engine.
Old 06-22-2011, 09:08 PM
lt4malibu's Avatar
it came with the TCI flexplate i bought a while back for another swap, i saved it incase i needed it. hughes sells one also to work with their flexplate
Old 07-02-2011, 05:03 PM
lt4malibu's Avatar
made some progress today:
pulled the motor back out so i could put the converter in and bolt up the Hughes flexplate, set the motor back in and started putting parts back on. waiting for the carb, and i need to find some radiator hoses and it should be ready to run. im going to rewire the engine compartment after it comes back from the chassis shop so its all temporary for now.
pic's:
flexplate and spacer
converter bolted up with the spacer
took the car off jackstands so i could roll it out and clean up the garage a little
Old 07-03-2011, 09:06 AM
ronnjonn's Avatar
I guess I should thank you for the info and pics about your troubles, but it's difficult to feel thankful now that I'm feeling worried. I ordered Morosos, and similar adapter plates, for the 5.3 swap into my third gen Camaro.
If you have trouble with those non-solid mounts, my idea is to grind the block's mounting bosses about 1/8" on each side. That's what I'll try if my Morosos don't fit.
Old 07-03-2011, 09:42 AM
lt4malibu's Avatar
the mounts that came with the transdapt kit fit perfectly - i could have made the solid mounts work by elongating the holes but it didnt seem worth the effort for now.
Old 07-03-2011, 09:47 AM
ronnjonn's Avatar
I assume those Morosos worked perfectly with your last SBC, right? If you elongated the holes, then that would no longer be true. So you wouldn't be able to revert to SBC power if the need happens.
Anyway, I'm glad you got yours going. I'll be watching for a timeslip.
Old 07-03-2011, 08:25 PM
pmgm's Avatar
Nice swap...What's the part# on the mounts you used?
Thanks
Old 07-04-2011, 07:11 AM
lt4malibu's Avatar
transdapt 1inch setback http://www.summitracing.com/parts/TRD-4595/
Quick Reply: time for a new project: 1978 malibu LS swap
