UK Project BMW E46 357ci V8
Old 06-13-2011, 06:04 PM
bikealarmblair's Avatar
Default UK Project BMW E46 357ci V8
I thought you might like to see my little project I've been doing & am part way thro. I've been posting it on E46Zone so I've copied it over hope it works...
As some of you are already aware I do some wiring work for Craig Taylor @ DynoTorque / CAL Sport apart from running a motorcycle dyno Craig is also an expert fabricator/engineer & puts LS 1/2/3 engines into different cars I've wired a dozen or so up for him & the V8 rumble/torque has finally got under my skin so he's making me one
I've bought a 2001 325 M Sport Coupe for the conversion into which is going an LS1 5.7l GTO engine & 6 speed box, it's not 'just' an engine swap tho it'll need hand made header pipes, prop, steering rod etc & while we are it were installing the rear end from an E46 M3 to give the car an LSD upgrading the suspension & brakes as well as sorting all the niggles with the car.
It's going to take quite a while to do & the engine is on its way from Canada & should land end of May or early June, in the mean time I'm assembling/sourcing all the parts etc
The Car...
M3 LSD Diff & rear end
LS1 5.7l GTO Engine & box
Laser cut widgets for the custom headers
The Carbon cube trim was worn out on the drivers door & needed replacing as I had to the door trim off to fix the CDL I decided I'd have a go at painting the trim & see what it looked like
I think it looks ok not sure if I'll do the rest or just get a new carbon trim for the drivers door
All the old bits engine/box/ecu/diff etc will be up for sale soon if anybody is in need of parts.
Rear AP calipers being sized up for brackets onto M3 read discs
A quick update or backdate
I sourced an M3 propshaft from a local breakers for £95
Brakes are proving to be a tad more trying tho...... The rear AP I'd sourced was TVR Cerebra I have a mate who has one (suprisingly enough with an LS V8 in it) & he had a matching AP for the other one I had so we swapped only for me to discover his AP a rear & mine is a front!!! Never mind I'm still going to get the brackets made up & when another rear caliper turns up I'll fit them then.
Front brakes are causing problems too well the brembo I won on eBay hasn't turned up lots of comms from the seller before I paid & zero since, his auction said the item was in Malvern & cash on collection but when I'd won he made some story about being on holiday in Aus for 5 weeks & his sister had them in newcastle so he could only post them etc... So I'm currently going thro the eBay dispute system....
Well I have to give eBay a thumbs up money was back in my account by lunch time yesterday & I 'think' I may have sourced some AP 4 pots too
Loobed my old black MV1's on still not sure on what to do about wheels unlike most I really like MV1's but this is 3rd car that's had them,,,,
Well the scales say 1421KG lets see how much it gains when it's finished.
Craig measuring up for the mounting brackets for the AP Calipers & bigger discs
Brakes
It needed a small spacer to clear the wheel but I'd intended to run spacers as the wheels sit to far in anyway so I popped next door & pinched some from driftworks....
Next up is the AP rear calipers
While I was @ driftworks I got Phil's old H&R anti roll bar off him for mine, my pile of stuff in the corner is getting bigger
Ready for bodyshop
Rear brakes are done
Car is back from bodyshop & Droftworks brought round a load of boxes (HSD's anti rollbars brakelines & loads of powerflex bushes.
The new radiator, engine mounts & fuel pressure reg/filter have been delivered too.
Engine should be here next week too Craig is stacked with big jobs so I doubt much if anything will start to happen for the next week or two but I'll be badgering him lots n lots!!!
Shiny things
Tomorrow I'm taking the subframe/diff etc out so I can measure up for the additional suports, I guess the project starts in ernest tomorrow
The engine is just waiting for customs clearance then I'll be off to London Port to collect it, I'm ready to burst!!!
We have started!!!
Complete back end removed so Craig can stiffen up the subframe mounting points
& it's a good job we were planning to stiffen the back end up.... the trained eyes will see the crack starting & the movement on the spot welds
Today I've removed the 2.5 engine/gearbox/wiring & front suspension.
Old 06-13-2011, 06:05 PM
There isn't a lot of the car I bought left...... Tomorrow will be spent delivering all the bits I've removed to it's new owner & gettibg the boot floor ready for the DynoTorque upgrade kit.
Oh & more shiny stuff arrived today too
The DynoTorque subframe kit waiting to be fitted
I've not done much the last few days, Craig has had a look at the engine & the clutch is fubar'd It seems clutches are a weak point on LS1's & the clutch of choice is an LS7 but to fit an LS7 clutch you need an LS7 flywheel too all in about £700 ish Why did I buy that cam LOL after a bit of surching I found a brand new one that's been taken off a new engine for £300
Ive put the new front shocks on
Craig busy making a racket grinding & then welding in the DynoTorque subframe strengthening kit
Tomorrow I'll finish re-bushing the M3 subframe, anti roll bar & trailing arm & start sorting brake lines then I can re-fit the petrol tank & subframe maybe....
Painted the repair
Subframe poly bushed
& then got it back into the car
Got the rear suspension & brakes on & ran new braided brake lines to the front
How sad am I
Craig's been busy today
He's made an new steering arm & relocted the ABS
Going to be a slow couple of weeks on this now when I ordered the engine I ordered it with a certain type of sump unforttunately the breaker didn't have one so he fitted a different one thinking it would be ok so after a quick measure up it defo won't fit with this sump & I've been able to source one in the UK so the sump he's fitted is being sent back & a the correct sump is being sent out to me, so just a case of being patient which is something I fail at!!!! The frustraiting thing is had he asked we'd have told him the sump he fitted wouldn't work.... until the sump is in Craig can't mount the engine, so he can't make the headers or get the propshaft modded & I can't start the wiring etc....
Anyway I can't post without one pic so here's what the engine looks like with no sump
I've made a start on the wiring....
& pushed it outside for a wash
The black wheels look better clean & in the sunlight
& That's where I'm at stuck waiting for Calspeed to send the correct sump & ThunderRacing to send the cam...
Has anybody else done one of these & can give me some help with the can bus tacho & coolant temp??
Blair
Old 06-13-2011, 06:21 PM
Jimbo1367's Avatar
Looks like its gonna be a killer ride. I like the silver rims. What color are you going to stick with?
Old 06-13-2011, 06:33 PM
Thanks
I'm still undecided on wheel colour some days I love the black some days I think it needs to be silver.....
Old 06-13-2011, 09:18 PM
Irish350's Avatar
love it... be sure to show some info on how you get the ecm/bcm/gauges/canbus all linked up, thats the reason why i didnt go with this swap..
also, @ the clutch, ls7 clutch/ls2 flywheel is an awesome setup, although if you check the classifieds here you should be able to get a better price than 700gbp, even with a big shipping premium (just saw a couple sponsor threads recently there)
edit: arent the ls2s 364ci, as opposed to 357
Old 06-14-2011, 01:15 AM
I got really lucky on the clutch I found someone in the UK that had a brandnew LS7 engine that they were fitting into an Ultima with a dry sump & they sold me the the clutch & flywheel for £300
It's an Ls1 5.7l we don't use the cubic inch in the UK hence its a 3 series 5.7L & ci because its a coupe with injection = 357ci
Old 06-14-2011, 01:16 AM
gnx7's Avatar
this will be fun! Spend the extra money and get an aluminum flywheel....... The LS2 factory one is a pig.
Old 06-16-2011, 05:59 AM
As I said not much can be done until the sump etc turn up but I've been doing my best to keep it moving along...
All the brake lines are now connected to the moved ABS pump
Done as much of the wiring as I can for now
What do you do when you can't buy a big enough back box? Well if your Craig Taylor you just cut/weld/bend one till it's the right size....
And then this morning Fedex handed me a package....
Just waiting (still) on the sump despite lots of assurances from the place I bought my engine (Calspeed & Performance) from were still waiting for them to sort their mistake out.
Old 06-22-2011, 04:40 PM
A minor update
Sump has finally tuned up late today so things should start moving forward, not that we've been idle while waiting for it..
Craig has fitted the new cam, cam chain, pushrods, uprated valve springs & collets
The engine just waiting for the correct sump.....
We've been able to do a bit on the exhaust & some of the pipework under the bonnet
A friend of mine has been over today looking at the canbus side of things & it's quite involved & going to take some work to do so as temp quick fix I'm going to install a set of E36 clocks I have while Rob works on the can bus.
Old 06-23-2011, 05:08 PM
The engine is in the hole !!!!!!!!!!!!!!!!!!
Excited me................................................ MUCH!!!!!!
This morning Craig fitted the LS7 clutch & T56 gearbox together & then poked the engine into the hole.....
& the he made some engine & gearbox mounts
& it's in
That's a very long difficult day made to sound very easy.... it's not trust me!
I've dropped the prop off to be shortened & have the correct end fitted for the T56 box & in the morning I'm off to Jetex to collect the bends & pipe/parts so Craig can start making the headers
Did I mention I'm excited!!!
Old 06-23-2011, 06:04 PM
SAATR's Avatar
That is absolutely gorgeous! I've always wanted to drop an LSx into a E31 of some flavor, but they're rather hard to find in good shape. All I can say is perhaps, perhaps, perhaps... Incredible job on the fit up though, I can't wait to see the final product!
Old 06-29-2011, 07:52 AM
It's been a busy few days for Craig @ DynoTorque he,s made the exhaust headers & connected them to rear section along with sorting power steering lines.
This
Old 06-29-2011, 10:03 AM
überschnell's Avatar
Nice build!
Old 06-29-2011, 10:18 AM
Tongboy's Avatar
very nice
whats your plan on addressing the CAN bus for the rpm input & related?
Old 06-30-2011, 03:16 PM
Well I guess you could say we've been busy....
& she runs
http://s1196.photobucket.com/albums/...t=b3371d83.mp4
Old 06-30-2011, 03:36 PM
72chevelle6.0's Avatar
Very Nice.. looks pretty factory too..
Old 07-01-2011, 01:47 PM
Still plenty of work to do before it's finished if a car like this is ever finished.....
Seems like I've got a faulty brake master cylinder as I no pressure to the rear brakes, not ideal
Needs to have the wheels aligned etc & still quite a bit of wiring/interfacing to sort out so still a few late nights left in it yet!!!!
But I'm a happy chap Craig's work is amazing I can't thank him enough for the work he's done & the endless advice & use of his workshop for the last month or two, I honestly wouldn't trust anyone else with car/van/bikes
Old 07-03-2011, 06:29 AM
Oh yeah it's gained a bit of weight..... It's 1499kg so 78kg heavier not all of that is engine tho, it's down to bigger brakes/wheel spacers/anti roll bars/diff/boot floor mods etc so it's about the same weight as a STD M3
Old 07-03-2011, 09:11 AM
Jimbo1367's Avatar
Impressive. Don't you have a smog test though?
Old 07-03-2011, 09:42 AM
ronnjonn's Avatar
Great swap! I like it, a lot!
Not a new ZR1, but a huge step closer to The ultimate driving machine.
What you're building is what Jeremy, James and Richard should be evaluating.
I like yours because it's what the new 2010 Camaro should have been: small, light, balanced, with a light but strong IRS, and wheels that aren't way too tall.
Quick Reply: UK Project BMW E46 357ci V8
