LTX --> LSX Conversion Sticky
Old 08-04-2015, 09:55 AM
  #201
93Z2871805's Avatar
Originally Posted by MrSlinger85
Any of you running LS3 top-ends with Cable throttle bodies? What did you do to mount the cables on the LS3 throttle bodies, and what cables did you use? LS1 brackets don't look like they'll mount. Thanks.
I made my own bracket. I just used some angle iron and used the front 2 holes on the manifold to bolt it down.
Old 10-30-2015, 01:47 PM
  #202
GREAT_WHITE's Avatar
Issue I'm having at the moment is after everything is in the car the driveshaft is to long , can anyone she'd any light on this for me.
1996 Trans am
6.0 swap
LS 4l60e
UMI tubular k member
Moser 12 bolt
Old 10-30-2015, 10:50 PM
  #203
deuce4935's Avatar
Sounds like cutting of the driveshaft is required
Old 10-31-2015, 08:39 PM
  #204
Believe it or not I found that there can be some differences in the driveshafts , got a shaft from a friend that came out of a 98-02 and ends up being just right
Old 12-22-2015, 01:11 AM
  #205
LT1BADZ's Avatar
I plan on using these mounts if I can't find a stock LS1 k-member local. Cheaper than going with a tubular K-member.
https://www.holley.com/products/ls_p...ts/71221002HKR
Old 12-22-2015, 06:18 AM
  #206
Gunters96lt1's Avatar
Anyone know if these will fit tubular LTx k-member?
Old 12-22-2015, 06:01 PM
  #207
93Z2871805's Avatar
As long as the tubular one uses factory clam shell style, I would imagine so.
Old 12-23-2015, 08:42 AM
  #208
Yep that's what Im using now. Thanks!
Old 12-23-2015, 11:01 AM
  #209
RGSS's Avatar
Those mounts are supposed to be bolted to the OEM LT1 K Member.
I dont see how you could bolt them on a tubular K member.
Old 12-23-2015, 08:17 PM
  #210
93Z2871805's Avatar
If they use a mount that has the factory style clam shell then it would be the same as bolting them on a factory LT1 K-member.
Old 12-24-2015, 07:21 PM
  #211
sierravmax's Avatar
Yep all tubular k-members do not come with built in mounts.
Old 12-25-2015, 09:50 AM
  #212
93Z2871805's Avatar
Some come with built in pedestals like the MWC ones.
http://www.midwestchassis.com/k-members-crash-bars.html
Old 12-25-2015, 10:21 AM
  #213
sierravmax's Avatar
Apparently I miss understood what you were saying. I thought at one time I remembered seeing that tubular k-members were being made where you had to reuse the factory pedestals. I am very familiar with built in pedestals as I used the UMI roadrace ls1 k-member for my swap.
Old 12-25-2015, 10:31 AM
  #214
93Z2871805's Avatar
I believe you're right, I think for awhile only places like Racecraft, MWC, Spohn and Burkhart Chassis were offering ones with the built in mounts (LS1 only), the rest used factory bolt on style ones. However I don't recall seeing a built in LT1 mount, but in all fairness it's been at least 5 years since I've looked, lol.
Old 11-28-2016, 02:28 PM
  #215
For anyone curious I bought these mounts and they worked great. I have them mounted on a PA Racing tubular kmember. The motor is right where it should be (not pushed back like some other mounts).
Old 11-28-2016, 04:08 PM
  #216
sierravmax's Avatar
For anyone curious I bought these mounts and they worked great. The motor is right where it should be (not pushed back like some other mounts).
Were you able to retain the Lt1 steering rack?
Old 11-29-2016, 08:11 PM
  #217
No I wasn't. But I am running forward truck manifolds. I guess I should have said that. I think longtubes might fit though.
Old 11-29-2016, 09:50 PM
  #218
RGSS's Avatar
This is great information. I wish they would have been out by the time I did my conversion. After runnig tubular K members on both my Lt1 and LS1 F bodies I very much appreciate the OEM K member for its structural integrity and rigidity. Alignment is much easier and precise too. I would have chosen this route for sure.
Old 12-01-2016, 10:23 AM
  #219
I actually have them on a PA racing tubular kmember....but they would work just fine with a stock one as well.
Old 03-22-2017, 07:41 PM
  #220
Chased's Avatar
I'm going 408 in my 96 TA this thread is awesome.
BUT that wiring harness looks like it's going to have me going crazy
Quick Reply: LTX --> LSX Conversion Sticky
