a/c sealing
a/c sealing
i have a "block" on the back of my compressor that 2 lines go to and in having trouble sealing the block to the compressor.. i have used 2 different sets of 4th gen gaskets and they both still leak oil!?! am i missing something and this is the block
http://www.docsblocks.com/proddetail.asp?prod=AA0443
You mentioned using 2 different sets of 'gaskets', are these gaskets or o-rings? These types of a/c compressor fittings are designed to use o-rings and the o-rings should NOT be installed dry, lube them with fresh, clean compressor oil.
Read the description for this fitting, it's the same as yours but in a horizontal style (notice the reference to this fitting in your link)
Hope this helps.
Hope this helps.
