Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Old 05-18-2016, 06:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
LSx engine swap guides
Old 06-20-2012, 08:58 PM
You got me all excited g-body, and then I noticed there wasn't a link for thirdgen's, lol. That's okay though, it's good that you put the info out there to help those in need
iroczracer07 is offline
Old 06-23-2012, 05:33 PM
1997 Tahoe.
http://www.hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
...'cause I've been following it...
-KP
kpeters59 is offline
Old 07-12-2012, 04:14 AM
can anyone help me get info on how and what i need to put a ls3 in a 2000 z28
dave123 is offline
Old 09-03-2012, 05:07 PM
linicklo's Avatar
No fox body links?!?
linicklo is offline
Old 09-09-2012, 06:52 PM
blackbirdbrain89's Avatar
thats what im looking for... im dumping a lq4 in one now. for far its sitting in there with th350 on the back of it i found out the headers are going to suck.. f body might fit on the right side but the left is not even close....
they make a k member and mounts bit im going to try to make the stock k member work...
any help would be nice lol
blackbirdbrain89 is offline
Old 09-18-2012, 01:31 PM
MissTransam79's Avatar
Default 1979 ta ls3 tt any help would be nice
i have a plate form now i just need some guidance. what would be the best way to start my build on my tt ls3? parts where to get them things like that like i said any help would be great and thank you
MissTransam79 is offline
Old 11-01-2012, 11:16 AM
Originally Posted by mcbassin View Post
Anyone know if there is a guide to wiring harness modification on this site? I'm looking to convert a regular truck harness to stand alone.
someone please answer this!! lol i feel like ive been searching for days!
john-man628 is offline
Old 12-26-2012, 09:31 AM
Default Ls1 swap into 68-72 El Camino?
Ls1 swap into 68-72 El Camino? Thanks
randyp83 is offline
Old 03-01-2013, 09:31 PM
Default G Body LS Engine Mounts
I found both of these adjustable LS mount for the G Body, anyone used either one???
Attached Thumbnails LSx engine swap guides-dingo-g-body-ls.jpg   LSx engine swap guides-carshp-g-body-ls.jpg
Rwolf15241 is offline
Old 03-27-2013, 10:13 PM
Would be nice to have a guide for the Nissan 240sx 89-98
turbonola is offline
Old 05-31-2013, 09:38 PM
1981TA's Avatar
Default Printable LS1 Wiring Harness Guide
So, I was searching for guides on converting an LS1 wiring harness to work with an older car. I found all sort of great guides. BUT... nothing was really that printer-friendly. So, I took one of the better ones that I found and made a PDF of it. Hopefully, this will help you out.
File Type: pdf
1981TA is offline
Old 09-03-2013, 01:56 AM
  #32
Question G Gorce Crossmember & 4L60e
Got my LS1 & 4L60e in my '78 Cutlass tonight.. Finally.. First off, the trans dapt swap plates SUCK!
But I'm over them.
Go to install my crossmember, got the G-force from Summit.. And it's not working out right.. Only way I got it to line up with the trans mount and not hit the back edge of the pan, was to use the front bolt hole on the cross member and the last bolt hole on the frame.. Problem is, the frame ends after that last bolt hole. So I can't drill for the last two bolts in the cross member.. SO now I'm stuck.. I don't feel safe just having one bolt on each side b/c it can twist b/c half the x-member bracket is hanging off the rails.. I dunno if I got the wrong one somehow, or I need the extension bracket, or I need to make my own extension bracket..
Just wondering if anyone else has run into the same issue and how you solved it... ??
speedaddict78 is offline
Old 09-05-2013, 12:10 AM
  #33
YoungZman's Avatar
Which site is the site to do a 280z swap? will it show all of the costs and such also?
YoungZman is offline
Old 09-08-2013, 07:07 PM
  #34
any ls1 to s13 good links?
s14kouki is offline
Old 09-08-2013, 07:28 PM
  #35
I can make some swap info for G35/350Z Ls Motors if needed. I have all my photos and diagrams I used in my G35 402 LS/T56 Swap.
Jwilliams04 is offline
Old 09-17-2013, 09:21 AM
  #36
Default harness questions on 6.0 and 5.3
I've dreaming up the idea of swapping the 5.3 in my2000 z71 with a 6.0 its getting to be a tired truck at 257k. Question is is there any differences between the two as far as engine harness. And can the old ecu from the 5.3 be flashed to accept the 6.0 engine.. or would I be better off to get motor harness and ecu from the 6.0. If that's the case will that harness plug into my current plunge in the fire wall and transmission plunges. Truck already has a 4L70z trans upgrade..
waynemitchell is offline
Old 09-24-2013, 12:05 AM
  #37
BigEd_72455's Avatar
As far as I know, there is not much of a difference in those two motors. If you are just running bone stock and not a modified engine, I would look for motor and harness. ECU should be able to be flashed. Just look for the same year range as your truck.
or look over on www.lt1swap.com at the info he has there. He has spent 8 years compiling info and programming ecu's and building harnesses. He is a polite young man who will help you as much as he can. His phone number is on the site also if you want to call him up and pick his brain after 5 P.M. central time Monday thru Friday.
BigEd_72455 is offline
Old 09-24-2013, 12:06 AM
  #38
wire by wire guide over on www.lt1swap.com
He helped me with mine and flashed my ecu.
Absolutely zero problems!!
Plus, at $75 including return shipping, he is the cheapest ECU programmer I have found anywhere.....
Old 09-24-2013, 12:11 AM
  #39
Cost for each project can vary by as much as a couple thousand bucks. So many factors affect the final cost that there is only one way to have two projects be exactly the same cost side by side. That way is to start with identical cars that are totally gutted.. Even then, unless you are building two identical projects, you can and will have variations from each car. Engine type, cam, headers, heads, intake, fuel system, transmission, rear end, tires, wheels, paint and body work... and SO MANY MORE options.....
Old 10-04-2013, 05:36 PM
  #40
cobalt964's Avatar
I make the conversion parts, and do conversions to put ls 4.8 5.3 5.7 6.0 6.2 7.0 engines in the Porsche 911 Carrera chassis cars 1972 - 1994 bodies. I have installed the lsx motors in lots of other gm applications as well but specialize in porsches. from stock, mild, to wild full blown tube chassis race cars.
cobalt964 is offline
Quick Reply: LSx engine swap guides
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
