How do I wire this 02 connector/alternator wiring ??
I have some C5 02s and I'm going to solder Fbody connectors to match my harness.
The Fbody connector is red,black,tan and blue.
The C5 is brown,brown,tan and blue.
I think maybe the two browns are heater and it doesn't matter what way they are wired...am I right?
Also I'm using a C5 alternator. The connector plugs right in to my Fbody harness is the wiring(one wire LOL)in the same location.
Thanks in advance
Thanks in advance
F-body
Tan:HO2 Low signal
Purple:H02 High signal
Pink:Voltage supply
Black:Ground
What year C5 is the O2 sensor from? I looked at both 98' and 02', and they list the same schematic.
I beleive the alternators are the same and you won't have any trouble, I read a thread on here that someone swapped their F-body alternator for a truck one and there were no mods, so I assume the C5 is the same way.
Hope this helps
Tan:HO2 Low signal
Pink:Voltage supply
Black:Ground
Hope this helps
F-body
Tan:HO2 Low signal
Pink:Voltage supply
Black:Ground
Hope this helps
Tan:HO2 Low signal
Pink:Voltage supply
Black:Ground
Hope this helps
Thanks for all the info/advise guys
