can any oil pan be swapped onto a 03 5.3L?
Old 08-03-2011, 06:01 PM
TXjeepTJ's Avatar
Default can any oil pan be swapped onto a 03 5.3L?
posting for friend, he put a 5.3L into a jeep TJ and wants to use an engine skid plate on it, but the 5.3 oil pan hangs way too low
He is looking at putting a c5 vette oil pan on it to cut off about 5 inches of depth. Can he do this? what will be needed?
Old 08-03-2011, 06:13 PM
gofastwclass's Avatar
Yes, you need the pan, windage tray and pickup tube - beyond that they are all interchangeable.
The exception might be the dry sump LS7 because it requires all the dry sump gear (oil pump, longer crank, external tank, etc.).
Old 08-03-2011, 07:22 PM
jomomma's Avatar
You should do a little research on here to see if there is a better pan he can use. You can do a search on here. They have a list of all factory pans and their demensions.
Quick Reply: can any oil pan be swapped onto a 03 5.3L?
