Can A Crank Pulley Be Put On Too Far?
Old 08-10-2011, 03:08 PM
LS1GMCTruck's Avatar
Default Can A Crank Pulley Be Put On Too Far?
Can an LS1 crank pulley/dampner be installed too deep, or on too far? Mine seems to be on too far & causing belt alignment issues. Thanks for any advice.
Old 08-10-2011, 03:52 PM
Cam72aro's Avatar
No. they tightened down and bottom out on the crank.
Old 08-10-2011, 08:44 PM
GNCLONE's Avatar
Did you change balancers? Vette, F body, and truck are three different depths.
Old 08-10-2011, 08:45 PM
S10xGN's Avatar
Only two scenarios come to mind:
1) The wrong offset pulley which would result in a huge misalignment (~ 3/4").
2) Your setup had the friction washer between the balancer and gear and it was left off (~ 0.080").
Old 08-11-2011, 05:52 AM
Yes I did, but also installed all the corresponding Vette accessories.
Old 08-11-2011, 05:56 AM
Would the absence of that washer then allow the dampner to be pushed on too deep? Or only the extra thickness of the washer itself, 80 thousanths?
Old 08-11-2011, 07:36 PM
S10xGN's Avatar
It would only be the thickness of the washer. You haven't said how much misalignment you have...
Quick Reply: Can A Crank Pulley Be Put On Too Far?
