98 wireharness conversion to 99-02 help
Old 09-10-2011, 01:02 PM
Travose21's Avatar
Default 98 wireharness conversion to 99-02 help
i have done the swap over from my 98 trans am. now i have a problem it wont start. I need help. the only code it is giving me is a p0122 code and that is the throttle position code. car has my 98 complete tune and now i need some help. all of the anti theft is out and all. when i crank it it cranks and imeditly goes dead
Old 09-11-2011, 07:27 AM
Travose21's Avatar
Anyone
Old 09-11-2011, 10:47 AM
Pocket's Avatar
Pinned it wrong
Remove the harness and do a continuity test from every single pin to their respective connector. More than likely you'll find multiple wrong because a simple TPS error wont be enough to kill the engine
Just to be sure, recheck the tune file that ALL of the VATS stuff is turned off. Fire and immediately die sounds just like it
Old 09-11-2011, 02:48 PM
69 Ghost's Avatar
Try the crank position sensor behind the starter. Did you remember that?
Old 09-13-2011, 11:51 PM
Travose21's Avatar
going to look over everything tomorrow any more input
Quick Reply: 98 wireharness conversion to 99-02 help
