Chevelle 4.8 Turbo
Old 12-29-2011, 03:05 PM
99VetteFRC's Avatar
well the C5 has an air filter on the end of the stock maf, corsa mufflers (on the car when purchased) and C6 Z06 wheels that I got cheaper than had I bought runflats for the stock wheels.The HP Tuners says its the easiest tuning software to use, I don't think so, but I no experience with it. Some things look easy but changing tables and fuel curves are tough. Although the engine isn't in the car running so I can't do too much. At this point I don't have a MAF for the 4.8, but when the turbos go on I have already downloaded a base speed density program, so there will be no MAF. Still researching and learning and collecting parts.
Old 12-29-2011, 04:47 PM
TOOSLO5's Avatar
Default Sweet project!
Love the 70 body style the best but my 72' and 66' will do! Good luck with the project.
Old 12-29-2011, 05:02 PM
71 chevy's Avatar
use one t70. it will still make about 700hp on a 4.8 and will spool FAST
Old 12-29-2011, 07:04 PM
99VetteFRC's Avatar
Here are a few pics I took of my 4.8L that I took today.
Attached Thumbnails Chevelle 4.8 Turbo-dscn1060-copy.jpg   Chevelle 4.8 Turbo-dscn1063.jpg   Chevelle 4.8 Turbo-dscn1064.jpg   Chevelle 4.8 Turbo-dscn1065.jpg   Chevelle 4.8 Turbo-dscn1066.jpg
Old 12-29-2011, 07:07 PM
99VetteFRC's Avatar
Well I've already bought the 2 t70s. I really like the look of the twin turbos. Not looking to make racecar horsepower, just to look cool when I go to the car show.
Old 01-03-2012, 10:18 AM
99VetteFRC's Avatar
Does anyone know why MAF sensors are usually deleted and software is changed to speed density for forced induction engines?
Old 01-03-2012, 10:54 AM
Chicago TDP's Avatar
From what I was told, you can only run up to about 500 hp with a MAF.
Anything over that and the MAF cannot support the tuning.
Also, I believe it might be simpler and more efficient to tune with speed density.
Old 01-03-2012, 04:22 PM
99VetteFRC's Avatar
So what IAT sensor should I use? The '03 the IAT sensor and the MAF are together in one part?
Old 01-03-2012, 05:02 PM
ls1_chevelle's Avatar
GM syclone GM# 25036751 38 bucks
Its 3/8" NPT so find yourself a bung to weld into the pipe aswell. The other styles are a rubber grommet and I always see them duct taped and ziptied to the pipe due to popping out. Can't go wrong with threads!!
Old 01-03-2012, 07:17 PM
99VetteFRC's Avatar
Nice, thanks for the advice. How about the calibration? Would it be the same as the one in the MAF?
Old 01-04-2012, 12:04 AM
You'll need to do a speed density tune. Find yourself a cobalt 2 bar map sensor. Or gm map 3 bar sensor if you plan on over 15psi. I am on my phone and cannot search a part number for ya but search in the forced induction section for those map sensor part numbers. The aem 2.5 And 3 bars seem to fail often. Gm ones are very reliable.
Old 01-04-2012, 04:45 AM
  #32
99VetteFRC's Avatar
I have a 2 bar map to fit the truck intake. Got the part number out of Hot Rod Mag on their turbo build. Gave list of part numbers. I also have a speed density OS in my HP Tuners to put in once the turbos are on the engine. I have zero experience tuning, so when I get it all in the car I will need lots of help!
Old 01-24-2012, 08:06 PM
  #33
99VetteFRC's Avatar
Just a little update. Things are a little slow at work so getting some funds is kinda tough right now. I did manage to get a MAF that I'm gonna use to run the engine on the stock tune untill I've collected the parts to put the turbos in the car. I also managed to get the spacer for the flat flexplate my wife got me for Christmas. The next big purchase I'm saving for is the Aeromotive A100 inline pump. Hoping to start the install in the next few weeks.
Old 01-26-2012, 06:23 AM
  #34
99VetteFRC's Avatar
So an update with some pics!! Have the flat flexplate for the 700r4 and got my spacer in the mail Monday. I also modified the fuel rail and mounted my fuel regulator.
Attached Thumbnails Chevelle 4.8 Turbo-dscn1089.jpg   Chevelle 4.8 Turbo-dscn1060-copy.jpg   Chevelle 4.8 Turbo-dscn1080.jpg   Chevelle 4.8 Turbo-dscn1063.jpg
Old 02-02-2012, 06:08 AM
  #35
99VetteFRC's Avatar
Progress isn't moving forward as fast as I had hoped it would. I keep doing little things though. I tapped the back of the right head for the mechanical temp guage sender and tapped the adapter by the oil filter for a mechanical oil guage as well. Wish I could get some money together for the rest of the parts so I can start the real work.
Attached Thumbnails Chevelle 4.8 Turbo-dscn1095.jpg   Chevelle 4.8 Turbo-dscn1096.jpg
Old 02-03-2012, 06:11 PM
  #36
williamkeller23's Avatar
sorry if i missed it but are you planning on keeping the a/c. if not has anyone with an a body been able to do this. im not willing to give up my a/c.
Old 02-03-2012, 10:26 PM
  #37
99VetteFRC's Avatar
Got my longer flexplate bolts today. Almost ready to buy fuel pump too.
Old 02-07-2012, 09:51 AM
  #38
99VetteFRC's Avatar
Got my A1000 fuel pump yesterday.... Will begin the swap on Friday.
Old 02-07-2012, 06:02 PM
  #39
68BBChevelle's Avatar
Awesome build keep the pics coming!
Old 02-09-2012, 06:31 AM
  #40
99VetteFRC's Avatar
These are some recent pics for progress made. Swap starts tomorrow.
Attached Thumbnails Chevelle 4.8 Turbo-dscn1097.jpg   Chevelle 4.8 Turbo-dscn1099.jpg   Chevelle 4.8 Turbo-dscn1112.jpg   Chevelle 4.8 Turbo-dscn1114.jpg
Quick Reply: Chevelle 4.8 Turbo
