84 camaro?
Old 12-30-2011, 01:57 PM
Ph.D. in HUBRIS
custm2500's Avatar
Default 84 camaro?
What do I need to do to install a 6.0 into my 84 camaro? It is a 5 speed. Will the bellhousing bolt up. Will I need to change flywheels. What about the computer will it need any help since the tans is differant? I have EFILive.
Aside from the trans it should basicaly be motor mounts correct? I know it is slightly more complicated then that but I can over come those things. Just not sure what the computer will think and what it takes to get the trans to mate and work properly.
Thanks
Old 12-30-2011, 02:02 PM
FatfreeGTO's Avatar
Are you using the stock 84 5spd? If so I would look into changing that, its not strong enough. GM only put them behind the v-6's and 305's back then because they weren't even strong enough to put behind the 350's you could get in a thirdgen.
Sorry I don't have the answers to your questions.
Old 12-30-2011, 02:08 PM
HeavyMetl's Avatar
You need f body accessories, oil pan, and intake manifold. The truck stuff doesn't fit. You'll need to research the wiring harness connections, install a good fuel pump, and get some sort of guages. Go to thirdgen.org and visit the LTX/LSX forum, read the stickies. I've done the swap, its not as easy as some imagine, but nor is it difficult.
Old 12-30-2011, 08:48 PM
LS1Tech Sponsor
psiconversion's Avatar
The computer doesnt care what trans is behind it, as long as the program is set up correctly. For your application you would go with a manual transmission OS. I agree with FatFree, I would consider a different manual transmission if you want it to last.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 12-30-2011, 09:45 PM
RPD_Vette84's Avatar
lots of info here: http://www.thirdgen.org/techboard/lt...third-gen.html
and peoples swaps here: http://www.thirdgen.org/techboard/ltx-lsx/
both my build threads are in my sig.
