Front end alignment setting
Are there differences in the way a manual vs power steering car should be aligned? I put a manual rack in a car that was originally power steering.
I would not think there would be any different in them if you check the FSM for spec.. But I would consult your alignement tech on any custom setting. And as CFster is suggesting, there is some changes you can do to improve steering performance. But for a Street driven car. Go easy on the changes.
BC
BC
