5.3l/4L60E into 87 Silverado
Old 02-22-2012, 04:49 PM
the_merv's Avatar
Default 5.3l/4L60E into 87 Silverado
I'm helping a guy install a 5.3 LM7 & 4L60E combo into a 1987 Silverado Reg Cab Short Box. Drivetrain was installed already by some of his friends, then they got to the wiring and were like ..so I was asked to check it out.
Engine & Trans is in there and mounted, what Headers are you guys using in these trucks? Stock Drivers Manifold clears with some play room, Passengers side with EGR doesnt clear the frame. It doesnt even look like that one without EGR will fit..I've seen a few of these trucks done so I figured I would ask. Thanks.
Old 02-22-2012, 06:43 PM
dec010974's Avatar
Default 87 c10
Hey Merv and ls1tech fam. I used jba shorty headers. i had to notch the frame on the driver side. (2) other friends of mine installed factory headers and they bothl had to notch the frame on the driver side. when you find a set that clear let me post to inform me.
Old 02-22-2012, 10:08 PM
496chevy's Avatar
i used the pace setters from the 99+ 5.3 truck long tubes... dent the headers with a piece of pipe and hammer, a little frame notching and they fit, barely.
Old 02-23-2012, 12:28 AM
the_merv's Avatar
I was looking at that too...seems that the truck frame is the same from the 60's to 1987..last year of it being a pain in the ***..
Old 02-23-2012, 12:57 PM
k5383's Avatar
Im running the 88-98 Lsx swap headers.
But Im 4x4 with a big lift.
Old 02-23-2012, 04:09 PM
the_merv's Avatar
How far above the Frame is the Cradle in that 4x4? You have any pics?
Old 02-23-2012, 05:18 PM
thepitstop2010's Avatar
I have a 85 c10 with a ls6. I am running first gen camaro shorty headers from sanderson.They fit great and didnt have to notch frame or dimple header at all. Hope this helps
Old 02-23-2012, 05:27 PM
Dothedew's Avatar
https://ls1tech.com/forums/conversio...silverado.html
Essentially the same thing. Non-egr manifolds do fit. Tight, but they work.
Old 02-23-2012, 05:39 PM
k5383's Avatar
Yeah, check my thread. "LQ4 into 84K k5"
Ill take some more clear pix later this evening when I'm home.
Old 02-23-2012, 09:16 PM
the_merv's Avatar
What Headers are they? That is def a 4x4..might be different from the 2wd I'm working on.
Old 02-23-2012, 10:41 PM
k5383's Avatar
Schofield 88-98 Lsx swap ones. Designed for 2 wheel drive trucks.
Old 03-06-2012, 11:47 PM
the_merv's Avatar
What about these...you guys think they would work?
Old 04-27-2012, 05:32 PM
Ford_Assassin's Avatar
Which oil pan did you use?
Quick Reply: 5.3l/4L60E into 87 Silverado
