51 Ford truck
Old 02-26-2012, 05:01 PM
nos487's Avatar
Default 51 Ford truck
I do not know how long it will take to finish this build but here are some pics. I hope to have a drive anywhere rat rod.
51 FORD F1 sitting on s10 frame
5.3 out of 04 Tahoe and 4l60e out of trans am.
Old 02-26-2012, 07:23 PM
S10xGN's Avatar
I like it! Hey, are those rear fenders swapped? Looks like a right-side fender on the left side of the truck...
Old 02-26-2012, 07:57 PM
nos487's Avatar
Good eye, they are in that pic. The previous owner had them on that way, and with them mounted way higher. He did not have any running boards, so he could run them that way to get the wheels centered in the fenders. I have since moved the rear end forward and have them on the right sides and found me some running boards.
Old 02-26-2012, 09:42 PM
silverz28camaro's Avatar
cool, take your time and do it right..I've had the ls1 in my Ram for a little over a year now and still has a few bugs to work out ..
Old 02-26-2012, 10:48 PM
Chavezdel's Avatar
Like the build, Im currently in the same process with a 53 F100.
Old 02-27-2012, 09:18 AM
bczee's Avatar
Like the project !... I've got a 48' F1, but trying to leave it as a stocker.. since it was my Uncle and is a complete Truck with all of the parts there.. I just need to get the wiring redone as I was able to get the engine to run for a while, it has been in a garage since 1975'.
BC
Old 10-10-2012, 10:26 AM
Nisstek's Avatar
How's this project comin'....
Old 10-10-2012, 11:36 AM
bczee's Avatar
Yeah.. Whats UP !
Here are a few pictures of mine. Mostly just sitting there while I work on the Nova Swap..and now have to remove the engine in the Chevelle.. I slammed the Oil pan into a pot hole !...
BC
Attached Thumbnails 51 Ford truck-dcp_2566.jpg   51 Ford truck-dcp_2512.jpg   51 Ford truck-dcp_2514.jpg   51 Ford truck-dcp_2515.jpg   51 Ford truck-dcp_2517.jpg
Old 10-11-2012, 09:04 PM
nos487's Avatar
nisstek did you find a ls yet for the impala?
bczee nice truck looks like it is real solid. sorry about the oil pan.
I have been slacking but I did get my ecm back and have just about everything to get it to run. I need to finish up my harness and wire the truck. I hope to work hard on it this weekend.
Old 02-14-2013, 10:43 AM
50f1rat's Avatar
What wheels are those? I have a 50 f1 and was planning on putting it on an s10 also.
Old 03-05-2014, 11:26 AM
amfs1950f-1's Avatar
I too have a LS1 into F-1 with s-10 chassis. here check it out
http://www.s10forum.com/forum/f213/l...-f-1-a-552842/
Old 03-05-2014, 04:48 PM
BudRacing's Avatar
Those wheels do look pretty cool on there. Also curious what they are.
Old 04-28-2014, 01:31 AM
DW SD's Avatar
Cool build! I just got my L92 and 6L80 running in my '51. I love it. I suspect with the bigger exhaust I'm at about 430horsepower (factory says 405).
Let me know if I can help. The steering shaft and exhaust wanted to be in The same spot, so that took some maneuvering. Ultimately, I made the steering Column into a short version and mounted the wheel more like a modern car than horizontal like an old bus. I added a Ujoint in the cab.
I also built a cover plate for the DBW pedal that is mounted on two thick steel stand offs welded to the firewall. That had me scratching my head for a while (mounting the pedal)
To improve driving position I also straightened the brake pedal (left to right) and cut a few inches from it and rotated it a bit so you step on it vs. push it forward. More like a modern vehicle.
Took some sheet metal work at the lower firewall too.
The trans tunnel cover in my case needed to be raised about 1 1/4" in the front.
Doug
Old 04-28-2014, 01:34 AM
DW SD's Avatar
This is snaking the exhaust around the modified steering shaft and column.
Excuse the welding. Not my favorite shots. I struggled with getting a nice weld on aluminized steel. Probably user error.
Old 04-28-2014, 01:37 AM
DW SD's Avatar
Thumbs up.
I need to do a four link conversion as it doesn't hook up worth **** with the posie leaf spring in the rear. Axle wrap could not be worse.
Old 04-28-2014, 06:39 AM
aknovaman's Avatar
Here is something my buddy put together.
Hopefully it will encourage and motivate you a bit !
Old 04-28-2014, 10:12 AM
BudRacing's Avatar
LOVE the ratrod look and the CLEAN engine bay!
Old 09-24-2014, 02:35 PM
SLCviaAK's Avatar
update on this cool pickup?
Quick Reply: 51 Ford truck
