Let's see some 67-69 camaro ls swap, engine bays!!!!
Old 11-10-2017, 06:38 PM
  #101
Motown 454's Avatar
Originally Posted by -TheBandit-
That looks awesome Motown 454! Too bad lat-g is blocked at my work or I'd go check out your build. Do you have it posted anywhere else?
Thanks
Pro-touring.com has it. you may need the photobucket fix to see the pics.
Old 11-19-2017, 03:32 PM
  #102
Sex On Wheels
will69camaro's Avatar
Here is my work in progress.
Old 03-22-2020, 01:00 PM
  #103
Slade8308's Avatar
Default Front runner: did you use the original front runner configuration? A/C ?
were you able to drop in that ls2 and use the air conditioning location on the front runner?
Attachment 610229
Attachment 610230[/QUOTE]
Old 03-22-2020, 01:13 PM
  #104
Slade8308's Avatar
Were you able to use the original front runner for the LS2? I’m looking at buying that same engine
Old 03-24-2020, 01:15 PM
  #105
Ryan@ICTBillet's Avatar
Low-mount A/C is usually dependent on the motor mount arrangement you choose, as they like to occupy the same real estate in a lot of appplications. Most of the time, to save some headaches, you can go with a high mount A/C system, like our 551494X-1 (For the LS2) This sort of bracket will integrate seamlessly with a Vintage Air system.
If you like that Alternator-Power steering arrangement from the Corvettes, we offer our 551521X-1 which is a direct replacement for the Corvette brackets and accessories.
Let me know if you have any more questions. Me, or our sales staff would be happy to help you out.
www.ictbillet.com
(316) 300-0833
Quick Reply: Let's see some 67-69 camaro ls swap, engine bays!!!!
