LS1 fuel lines
Old 05-05-2012, 01:18 PM
harfab's Avatar
Default LS1 fuel lines
I am installing an LS1 in a 62 Nova. Since the fuel line doesnt have a return line, does the LS fuel pump an internal bypass? I need advice on how to run the fuel lines. Any help would be really appreciated!!!!!!
Old 05-05-2012, 04:21 PM
CutLS's Avatar
Alot of people run the '99-'04 Corvette fuel filter/regulator. it has a built in regulator so you can run a single line to your fuel rail. Usually you try and mount the filter/regulator close to the tank so you don't have such a long return hose to install. WIX carries their verison for pretty cheap.
Quick Reply: LS1 fuel lines
