Car intake on a truck with a truck water pump
I have always seen you must change the water pump to use a car intake. Tonight I'm setting my car intake on and put the truck t-body on and the water pump fit's. I needed to remove the tab for the cruise control off the t-body but it does fit and work perfect but it is a close fit.
I plan on rotating the water neck some but even if you didnt a small dimple would give you more clearance if desired. The truck motor is a 99 and the car intake is a early LS1 F-body intake.
Theres a smaller 105 amp Alt. that bolts right on that gives about a inch from what I've found so far. I havent grabbed one yet though to compare.
Thats a slick setup but I dont think it will fit in my application. My front end is narrowed and theres 2 coilover towers under the hood straddling the engine with a brace over top.
http://inlinethumb01.webshots.com/26...600x600Q85.jpg
