crank spacers??
Old 06-01-2012, 04:46 PM
overhere's Avatar
Default crank spacers??
i had a 6.0l and a th400 with the correct converter to go up against a sfi flywheel. and i didn't have a spacers i know certain years need them because of the longer and shorter cranks. im going to be getting a 5.3l is there any years that would need this spacer?
Old 06-01-2012, 05:40 PM
Bo185's Avatar
The 1999-2000 6.0L's have the longer crank flange. The 5.3L never had the longer flange.
Old 06-01-2012, 06:32 PM
99VetteFRC's Avatar
Flat Flexplate Gm Part #12621399
Spacer 12563532
Bolts 12563533 x6
All available from your local GM dealership!
Old 06-01-2012, 07:12 PM
overhere's Avatar
so as long as my 6.0l wasn't a 99 or 2000 the 5.3 should bolt right up then?
Old 06-01-2012, 08:47 PM
overhere's Avatar
here is the set up i have now on the 6.0l. im going to be getting a 5.3l and i plan on using the TCI flywheel along with the same converter. will this all bolt up correctly?
Old 06-01-2012, 11:21 PM
Bo185's Avatar
That's the short crank flange 6.0l your good to go. Remove the dished 5.3L flex plate and run the flexplate you have it will all bolt together.
Old 06-02-2012, 06:03 AM
overhere's Avatar
thank you very much
Old 06-02-2012, 09:07 PM
S10xGN's Avatar
I got "peace of mind" by bolting it all up and checking for proper fit while it was on the ground where I could get to everything.
Old 06-03-2012, 08:40 AM
99VetteFRC's Avatar
Looks like your flexplate has all the spacers built in.
Old 06-03-2012, 08:54 AM
overhere's Avatar
thank you
Old 06-03-2012, 09:26 PM
S10xGN's Avatar
That flexplate is, ummm, different... I'd mock it up for sure after seeing that.
Old 06-03-2012, 09:28 PM
overhere's Avatar
why do you say that? i had this all together running on my 6.0l. im thinking about getting a 5.3l was just wondering if i needed anything different to make it work.
Old 06-03-2012, 09:36 PM
S10xGN's Avatar
If you're talking to me... Your first post didn't say that it was a running setup, just that you "had it". Regardless, with use of non-stock parts, I always mock-fit everything first. Then when it goes in the car, it's there to stay.
Old 06-03-2012, 09:41 PM
overhere's Avatar
i was just wondering why you think its different? im no pro just wondering. could of been wrong all together. got it from someone else along with other parts.
thats my fault for not wording that better. thank you for your time and help.
Old 06-04-2012, 09:05 PM
S10xGN's Avatar
Google up some pix of a factory flexplate and the difference will be obvious.
Old 06-05-2012, 01:34 AM
LS102ws6's Avatar
obvisously
Old 06-05-2012, 06:01 AM
overhere's Avatar
i realize its not a stock flexplate. its a sfi approved plate.
Quick Reply: crank spacers??
