69 Buick GS 415/T56
Old 06-11-2012, 09:48 PM
LS2GS's Avatar
Default 69 Buick GS 415/T56
After lots of searching/studying, I finally got enough stuff together to get started on my Buick project! I figured this would be a great way to document my progress and also help keep me motivated. My goal is to have a factory looking GS that handles like a new sports car, pulls like a rocket, gets 20 mpg, and I can flip on the ac while I am stopped in traffic with out overheating.
So far I have just installed a Currie built 12 bolt rear end, tied up with UMI upper and lower control arms. I test fitted the right stuff rear disc brakes just to find out that the factory 15" rally rims still rub. Oh well I was planning on getting new rear rims with some more back spacing to fit a wider tire in the future. Hopefully the fronts wont rub but it will be a bit before I find out.
Today I pulled the 455 out. Not sure how soon I will be able to start the mock up of the ls t56 combo, work, kids, and mommas honey do list always seem to get in the way.
Attached Thumbnails 69 Buick GS 415/T56-kite-flying-007.jpg
Old 06-11-2012, 09:52 PM
LS2GS's Avatar
For some odd reason I cannot seem to load multiple or even anymore pics. I will try later.
Old 06-11-2012, 11:03 PM
1989GTA's Avatar
I have a 1965 Skylark that I am putting an L92/6L80 into it. I will be following your thread with interest.
Old 06-12-2012, 05:53 AM
oldgoat69's Avatar
Looks good, similar to the goals I set for my project.
Old 06-22-2012, 08:21 PM
LS2GS's Avatar
I pulled the front clip off and started installing the new UMI front suspension and disc brakes.
Attached Thumbnails 69 Buick GS 415/T56-001.jpg   69 Buick GS 415/T56-004.jpg
Old 06-22-2012, 08:37 PM
LS2GS's Avatar
I have to say that the UMI suspension products are top notch and the tech support is superb. Sometimes I feel pretty dumb when I constantly call Ramey at UMI but he knows the products and has the answers I am looking for. The only real issue I have had is the new big a%# sway bar contacts the idler arm, but it should be a simple thing to fix. I also installed the 96 jeep grand cherokee steering box for an improved geer ratio.
Old 06-22-2012, 08:38 PM
gs462's Avatar
Nice ride was it a 350 oir 400 car?
Old 06-22-2012, 09:23 PM
LS2GS's Avatar
It was originally a 350 car, I wouldnt do the swap to a 400 car they are worth a few dollars more. Hopefully when its all done it will still resemble a "buick 350", I like the sleeper image.
Old 06-22-2012, 11:01 PM
Robofuzz's Avatar
Subscribed. I bought a '68 Buick GS with 40k original miles on it right after I graduated high school in 1988. I sold it a couple years later so I could get married. I'll always have a soft spot in my heart for the GS.
Old 06-25-2012, 11:49 PM
LS2GS's Avatar
Question
Today I slapped the mock up engine in to see how things were going to line up. I dont have my holley pan or even the tierods and center link in to check pan clearance, hopefully it will clear!?? I am using the dougs headers adapter plates and energy suspension tall and narrow mounts. Anybody use this combo with the holley pan?
The next issue is the GTO accessories. There is no way the ac compressor will ever work in the factory location, even if you notch the frame the 350 chevy engine stands are in the way. I was thinking about giving the Kwik ac relocation bracket a try when the time comes, does anyone have any experience with the kwik brackets and the gto accessories? On the other side, the alternator contacts the steering box as well as the alternator pulley. I have read that some people have used an f body alt due to its smaller size, will it work? If not what will without breaking the bank? And lastly the bracket that bolts to the back of the alt and to the block will not work with this engine mount combo. If I can get the alternator working in this position, how important is it to have this stabilizer bracket?
If anyone that has been down this road and has some words of advice it would be welcomed!!! I included some pics to show some of the issues
Attached Thumbnails 69 Buick GS 415/T56-002.jpg
Old 06-25-2012, 11:54 PM
LS2GS's Avatar
Cant figure out why I cant load multiple pics!!! Or how do you load then to be a regular size not a thumbnail
Attached Thumbnails 69 Buick GS 415/T56-004.jpg
Old 06-25-2012, 11:56 PM
ZNix's Avatar
LSX 455 would be awesome under the hood. But I like the swap. I can't wait to see the updates.
Nix
Old 06-25-2012, 11:58 PM
ZNix's Avatar
Don't attach the images through the forum. Upload everything to an image hosting site such as Photobucket. Then add it to the post.
Nix
Old 06-26-2012, 09:37 PM
LS2GS's Avatar
Trying the photo bucket thing! Still trying to get some ideas on the accessory drive.
Old 06-27-2012, 03:35 PM
gs462's Avatar
That ain't no 350 sitting in that engine bay that theres a bigblock
Old 06-27-2012, 09:05 PM
Johawk's Avatar
He said originally a 350 car. He pulled the 455 pictured to swap the LSX in
Old 06-27-2012, 09:07 PM
gs462's Avatar
I know what he said, I read it, I was just commenting that what was in the pic is a bigblock.
Old 06-27-2012, 09:12 PM
Johawk's Avatar
10-4. I thought you were confused...
Old 06-27-2012, 10:06 PM
LS2GS's Avatar
I did put a 70 455 in it last year, ran good and it was a torque monster!, but its time for a little more! To build a buick 455 to make 600hp will be comparable to my 415 wegner build in cost but the other benefits of the LS far surpass the old Buick. No offense to the purists.
Old 06-28-2012, 05:55 AM
gs462's Avatar
Yes you are correct I had a Buick 525 cu in built a few years ago made 740 hp and 720 tq but It was NOT cheap. The crank alone was almost 3k
Quick Reply: 69 Buick GS 415/T56
