Header building tech help for LS1 going in Jeepster
I've got a 99 LS1,with LS6 heads and ls6 intake. It has a comp cams 112 lsa cam .595 lift 232/232. This motor came out of a E36 track car.
I'm going to be putting it in a 71 jeepster commando. Jeep is already caged out,and running 1ton drivetrain on 37" tires, lockers etc.
I have the equipment and ability to build headers, but not sure if i want to go through the effort. I have too many other things to build. Should i build a set of tri y's or just try to bolt on some block hugers? I'm going to run 3' stainless pipes all the way back.
Last edited by locostuntguy; 06-21-2012 at 04:22 PM. Reason: Clarify title of post
LS1TECH & Trucks Sponsor
The longer tube header you can get on this vehicle the better. LS motors have always shown very good pick ups with long tubes over a shorty. I know you will be limited on space but its definitely worth it to put the extra effort in for a longer tube in my opinion.
Use this gear calculator...tells the truth http://www.grimmjeeper.com/gears.html
My LS TJ with 40" tires, 700R4, runs about 1700 rpm @ 55. My crawl basement ratio is 221:1. AT LOW LOW, 2200 RPM = 100' PER MINUTE
